Ive searched, stock ls1 fuel rail max hp?
Old 02-20-2014, 11:32 PM
Quickfrc's Avatar
Default Ive searched, stock ls1 fuel rail max hp?
I have a turbo 6.0. BW S475 through an auto running on 91 and a dual #5nozzle 50/50 meth kit. I should make high 600's rwhp,if not more. My tuner is saying that will not make any more than 550 because I will starve my injectors with my stock ls1 rails. My fuel system is a sumped tank, -10 feed to holley dominator duals, -8 to the holley boost reference regulator, -8 to the stock rails, -6 return. It seems that a lot of people are making plenty of power on the stock rails. I just cannot find any solid info. There are people sayin 1200 hp, then there are some saying no more than 500. Does anyone actually have first hand experience?
Old 02-21-2014, 12:11 AM
got-a-ls1's Avatar
tell your tuner i made 700+rwhp on stock fuel rails and 91. e85 would obviously limit things as well... when i pulled the engine down all pistons were perfect no signs of being lean or detonation anywhere. i believe skinnies made 850 on stock rails... and mine was on stock fuel line and intank regulator. if you have a regulator at the rail even better. that said i would say anywhere between 700-800 wouldnt be a bad place to really start thinking about replacing the rails. not like they are that expensive when you are talking about a 7-8 + hundred horsepower build haha
Old 02-21-2014, 12:39 AM
ZGLASS's Avatar
made over 900whp on mine. had to turn it down to 840whp to keep the duty cycle safe. pump gas 92oct and 80/20 meth
Old 02-21-2014, 01:24 AM
Quickfrc's Avatar
Are these claims through autos?
Old 02-21-2014, 06:52 AM
LS1NOVA's Avatar
Made 750whp through an unlocked auto with stock LS1 rails setup just like you described on E85.
Old 02-21-2014, 08:00 AM
mrstepheneades's Avatar
At the 900rwhp mark on my stock rails/lines/regulator. 21psi with a s475. FIC1000cc injectors. Twin 10gph meth nozzles using 100%. Pump 93. Im 6speed. Made a pull on 16psi and made 775rwhp. AFRS 10.8-11.0. Video in SIG.
Old 02-21-2014, 08:14 AM
HexenLord's Avatar
The biggest restriction is the -6 AN tube size, which is still good for 1200 HP.
Old 02-21-2014, 08:38 AM
Compressor Surge's Avatar
Can you post a pic or two of how you connected to the stock rails? I have a build in progress and I want to use an aeromotive return regulator, but use the stock rails and fuel rail/coil covers.
Old 02-21-2014, 12:49 PM
LS1NOVA's Avatar
Run the single feed line into the side of the regulator, run it out the other side and into the rails. Run the return from the regulator back to the tank.
Old 02-21-2014, 03:11 PM
Forcefed86's Avatar
I personally made around the same power that your looking to do with the LS1 rail on E85. With pump gas and enough pressure you could make your goals with the OEM fuel lines and rail.
IMO I would look for a tuner with direct LS turbo experience. Not some goober trying to sell you things you don't need.
Like so...
I'd post my car but you can't see it as well. This car made 850whp on OEM rails on E85. -6 from regulator to rail.
Old 02-21-2014, 03:28 PM
Quickfrc's Avatar
Thanks for the input guys!!!! More info the better.
Old 02-25-2014, 11:40 AM
Hmm, I see that you guys are "deadheading" the rails. No issues with that? My setups have always located the bypass regulator after the rails have been fed. Do you tune for it in the stock ECU the same as any other manifold referenced fuel system?
I was planning to TIG some fittings on both ends of the rails, with a crossover and plumb it like I always have, but I kinda like this idea. The results of Forcefed's car seems to indicate that it works well.
Old 02-25-2014, 11:56 AM
Forcefed86's Avatar
After the rails is better IMO. But not worth the extra cost and effort in my JY type build. Skinnies (thats his car in the pic above) and a few others have made over 850whp on E85 with the rail dead headed like that.
Not sure the power I was making but I was running 25lbs of boost on my s475 on E85 with mine.
Old 02-27-2014, 01:28 PM
Sweet. The setup I'd be doing this on is nowhere near a max effort....or even a moderate effort setup. Just a 500-600 whp LS6. Thanks for the info, I might give it a shot.
Old 01-11-2015, 10:51 PM
BC178's Avatar
Old thread, are you guys just running double pumps and a return line for this 800hp range? I'm at that range and was just curious.
Old 02-29-2016, 09:14 PM
Bitchin'Camaro's Avatar
What fuel pumps are you guys running?
(Back from the dead)
Old 03-10-2017, 09:00 AM
Jlj21usmc's Avatar
Default Staying Alive..
Looking to stay in the 550-600whp range, turbo LQ4. Planned on using factory rails deadheaded, with factory 3/8 feed line, an aftermarket regulator and factory return line. This is going in an LT1 car so the lines are the easy part. Now what fuel pump setup is recommended? Single Aeromotive 340?
Quick Reply: Ive searched, stock ls1 fuel rail max hp?
