LSX block, 377c.i., LS3, YSI, 17psi=870/730 on pump gas
Old 03-01-2014, 05:24 PM
Sales@Tick's Avatar
Default LSX block, 377c.i., LS3, YSI, 17psi=870/730 on pump gas
2013 Corvette Grand Sport
-LSX Iron Block
-4.070" bore Forged Wiseco pistons, tool steel wrist pins, steel top ring
-9.25:1 compression ratio
-Callies Compstar forged H-beam connecting rods
-Stock crankshaft from factory LS3 engine
-Durabond cam bearings
-ACL Race main bearings
-Clevite H series rod bearings
-ARP main studs
-ARP 2000 rod bolts
-ARP head studs (factory 11mm primary studs and 3/8" outer 5th & 6th bolt)
-Total Engine Airflow Trick Flow Specialties 255cc "GenX" 6 bolt casting cylinder heads with 50* exhaust valve job and hand blending.
-Stock LS3 intake manifold
-Stock LS3 throttle body
-Custom Tick Performance 227/247 .624/.627 115lsa camshaft
-Comp cams 3/8" diameter .080" wall thickness 7.500" push rods
-LS7 lifters
-BTR Platinum .660" lift dual spring kit with titanium retainers
-Stock LS3 rockers arms with trunion upgrade
-A&A Corvette Vortech 8-rib supercharger kit with flip drive
-YSi blower with 3.0" pulley
-Innovators West 10% overdrive balancer
-17psi boost with installed pulley arrangement
-Custom Bell intercooler core fabricated in house@Tick Performance
-Snow methanol injection system with 10gph nozzle
-Tick Performance built Level 2 TR-6060
-Centerforce DYAD twin disc clutch
-Tick Performance built C6 rear diff
-93 octane pump gas used for all pulls
The dip in power @6400rpm is from the IAT sensor pulling timing. Judging by how power was climbing it may of made 880 had it not. I believe it also pulled timing@4900rpm.
The air fuel is on the rich side and IMO is conservative. There is more power in leaning it out. The wide band sensor in the tail pipe the dyno uses is .5-.7 leaner on average than what is in the collector. We confirm this by reading plugs and we have 4 other portable wide band sensors that all confirm it's leaner.
The plan though is to leave it as such and go to the smallest 8-rib pulley A&A makes which is a 2.85". We're hoping this gives us 20-21psi. Judging by the power it made on 17psi, 21psi should deliver some very interesting results.
Old 03-01-2014, 08:56 PM
TDagen's Avatar
Almost 900whp on pump gas. Impressive!!
I see its on the tick tr-6060 also, awesome. Gotta love a huge power manual transmission car.
Old 03-01-2014, 09:32 PM
Detoxx03's Avatar
Are the accessories upgraded to 6 rib? Also how does the owner like that clutch?
Old 03-01-2014, 11:22 PM
Sales@Tick's Avatar
Accessories are not upgraded to 6 rib. The owner has not driven the car yet, but it feels nice IMO.
Old 03-02-2014, 07:00 AM
venom ws7's Avatar
Sick numbers I bet it will be over 1000rwhp on 21psi with little more aggressive tune.
Great work Martin and Tick crew I'm surprised you didn't go with higher compression??
Congrats to the owner love the setup small CI and big blower looks like if it didnt pull timing after 6400rpm it will be 900ish
Old 03-02-2014, 07:49 AM
Jimbo1367's Avatar
It would be nice to see NA dyne numbers. Not many TFS 255 builds /dynos # out there.
Old 03-02-2014, 08:51 AM
ls427ray's Avatar
nice numbers! but somebody needs a cog belt
Old 03-02-2014, 08:56 AM
Cubicylndr's Avatar
Martin, call/text me or pm me plz. I tried to pm you, but keeps showing an error msg.
631-223-6604
Mark
Old 03-02-2014, 02:40 PM
Sales@Tick's Avatar
We wanted a very safe set-up for this customer. He uses this car to roll race and compete in standing mile events.
We needed a set-up that he could stay in the throttle for extended periods of time and not have to worry about the tune-up being "on the edge". Especially when using pump gas. The owner was adamant about his tune not relying on a ton of methanol or race gas to keep the tune up "safe". Thus the lower compression.
I would also have to agree that it would of come close to 900, but I like to "guess conservatively" when I'm bench racing.
What I like about this set-up for being a centrifugal combination and small on displacement is the torque. 500rwtq by 3400rpm. I feel the small runner heads and smaller cam are helping the early torque numbers.
The flow sheet that came with these heads showed 380cfm@.700 and 245cfm@.700.
I have a customer with these heads, LS3 Polluter cam, Fast 102, 10.8:1 compression and the normal bolt ons that made 510/470 and has been 10.70's@126 in a full weight 3600lb. F-body. It's a 6 speed car and he lives in Florida so the air isn't the best. I believe the DA was 2000+ the day he ran that pass and was only shifting at 6500rpm.
Yes!
631-223-6604
Mark
Mark,
I do not receive PM's. Email or calling the shop is the fastest way to reach me!
Old 03-02-2014, 06:16 PM
RedMan*'s Avatar
Great info…. just saying…..
Old 03-11-2014, 05:02 PM
Sales@Tick's Avatar
Well guys we did it. We fabricated the new intercooler, tossed the smaller pulley on and these were the results. We know it has a 1000rwhp in it, but for now we're not going to push it and let the customer enjoy it.
It's been in our shop for a long time, and he deserves to finally enjoy all the money he has put into this pump gas beast.
Quick Reply: LSX block, 377c.i., LS3, YSI, 17psi=870/730 on pump gas
