Need advice on what gears to run on my turbo camaro
Hey what's up guys well like the tittle says need some advice on what gearing to run on my set up.my car is a 2002 camaro and currently have 9" with 370 gears with a 28" tall tire.and my set up is:
*Forged 383
*4l80e with a circle D converter (3600 stall)
With jakes trans brake
*Garret gt4788 turbo
*custom turbo cam
Would really appreciate any help ASAP.and thanks for the help guys
*Forged 383
*custom turbo cam
The calculator I used said that I would be at 64mph at 2,500 rpm with my th400, 3.25 rear gears (9") and my 325/50 tires (28").
The same calculator said that you would be at 75mph@2,500 rpm with that gear and tire.
Of course all of these numbers could be different depending on the "slippage" of the converter. These numbers should give a ball park figure as to what you are looking at.
