Twin turbo 5.3L in a Lexus Is300...sounds fun right?
At the moment we haven't turned up the boost. This build came together in the final minutes before we left for TX2k14. Honestly my body is still recovering from this build. We tuned the car @ 11 psi on our Mainline dyno laying down 700whp normally this dyno is a heart breaker reading about 18 percent lower than the dynojet.
When we made it to Texas I tossed it on Hennessey's Dynojet laying down 861whp @ 16 lbs with un-optimized ignition timing. It should make a little over 1100hp on 25 lbs.
I also haven't posted much about it but this is a 6 speed car. Running the RPS triple carbon clutch and a TR6060 from a CTS-v
Here's the only video I have at the moment. We're working on a full build video.
Matt
Matt
Also if you haven't read this article its not too late.
http://www.revvolution.com/blog/2014...-swapped-is300
The motec display is beautiful - Love the simplicity of this build. Great job - Looking forward to you leaning on the 4 bolt set up more to see how far you can push them without them pushing water back at you.
#35
Its the TR6060 from a 2012 CTS-V. I sent it off to RPM where they replaced all the soft parts and wear items. I also had the 31 spline Magnum mainshaft and F-body tail housing installed as well as a REM polish on all steel parts.
#36
Awesome to hear from an old MR2 fan. I still love the MR2 and I'm sure I'll own another one day. The heads are the Trick Flow 205's for the 5.3L Fully CNC ported from trickflow.
Matt
#37
[/QUOTE]Its the TR6060 from a 2012 CTS-V. I sent it off to RPM where they replaced all the soft parts and wear items. I also had the 31 spline Magnum mainshaft and F-body tail housing installed as well as a REM polish on all steel parts.[/QUOTE]
Awesome I was actually looking into them. They sound like they know their stuff.
