Wiseco pistons in turbo 5.3 what piston to wall clearance?
Old 03-31-2014, 01:19 AM
69Tinindian's Avatar
Default Wiseco pistons in turbo 5.3 what piston to wall clearance?
I ordered pistons and im waiting for them to show up. I run on pump gas 92. The motor will be 9.1 comoression and will prob run around at 12lbs and more with race gas. I figured 22-24 on ring gap but im curious what guys are running for piston to wall?
Old 03-31-2014, 01:57 AM
ultraspeed's Avatar
run what is suggested with the pistons. I will say it will be 4 to 5 wall clearance.
Old 03-31-2014, 12:25 PM
Ya that what I figured. Do you think .0055 is to loose in the bore and will it piston slap like a mother? I really dont wanna stick a piston in the bore. Its a iron block 5.3
Old 03-31-2014, 01:18 PM
runsfromdacops's Avatar
It all depends on fuel and how hard your going to push it. I went 55 and I made 900 on gas.
If you want more power then that I'd go 60ish
Old 03-31-2014, 08:07 PM
Wes Hardin's Avatar
we build them with 4-5.works great
Old 04-01-2014, 12:42 AM
[QUOTE=runsfromdacops;18120302]It all depends on fuel and how hard your going to push it. I went 55 and I made 900 on gas.
IT is truly a streetcar so I run it on pump gas 92. I do plan on turning it up once and awhile. The pistons I ordered will put it at 9.1. I was thinking .0055 also. Just wanted a second opinion so thank you. What is your setup? 900 thats making some power damn
Quick Reply: Wiseco pistons in turbo 5.3 what piston to wall clearance?
