microsquirt install
microsquirt install
i purchased a microsquirt plug n play kit for a L33 last fall and i am now installing it . I have lost wiring documentation and i am unsure which side of the harness goes on the drivers side and which goes to the passenger side . i am also not seeing where the map sensor goes.
any help would be appreciated
thanxs
mike
thanxs
mike
Here's the coil pack layout. The injector banks can go on either side since it's batch fuel. The map sensor can go wherever you want as long as it sources manifold vacuum.
https://ls1tech.com/forums/showthrea...912&styleid=27
if i am reading that link correctly that is for the universal wire harness.on the pnp kit it is already loomed and taped so i do not want undo the the loom to install the map if it i do not need to.
u 1 smart cookie , thanxs for the resistance. i mean assistance
Odd that they are not available.
I use microsquirt quite frequently.
If you have a ohm meter you can check for continuity between the coil and injector connector to the micro using these diagrams to determine what connector is what function.
http://www.useasydocs.com/details/ew3_hires.gif
http://smg.photobucket.com/user/denm...b72e3.png.html
If you still have difficulty figuring it out, you can pm me your phone and I can call and talk you through it.
i appreciate the help .
i will go out to the shop tomorrow and look at your diagrams
just for reference here is what i have.
there are two branches to this wiring loom
and the wiring colors are as follows
http://s3.photobucket.com/user/turbo...69489640941286
ok , i am back home to work on this again.
It was a whole lot easier to identify where some of the wires went after i purchased the missing TPS sensor.
I still have an issue with a couple of wires.
the 3 pin wire connector white / green / grey does not fit either the crank or cam position sensor
the 3 pin wire connector peach / white / red fits both the crank and cam position sensors.
Also I stil have to identify where the Map sensor wires go
the 3 pin wire connector white / green / grey does not fit either the crank or cam position sensor ------ MAP Sensor?
the 3 pin wire connector peach / white / red fits both the crank and cam position sensors. ----- Should be for the crank sensor, since Microsquirt does not use a cam sensor referrence
the microsquirt does not use the cam sensor. you should have a crank plug that has 3 wires but 2 will be in a silver shieth if you look in the loom up from the plug.
there will be a 3 wire that is for your map as well .
then a coolant,tps,iat
if you open the split loom up stream from each plug the sensor wire will be labeled.
