how can i get my turbo to spool faster?
Old 04-09-2014, 11:06 PM
awd-rwd racer's Avatar
Default how can i get my turbo to spool faster?
i have a L76 6.0 engine. ported 317's, tick 226/235 .605"/.610" 115+2 turbo cam, and a masterpower t76 with a .96 a/r. Im currently getting full spool around 4000-4200 rpm. around 10-11 psi. it pulls like crazy, but id like to get it to spool a little faster if i could. i currently have dual 3" merge coming off the headers. I did some reading that changing from 3" to 2-2.5" pipe merge would help with spool up with out sacrificing any power. any other tips or tricks i could try? i know its not a big turbo compared to some of what you guys run, figured it might spool a little faster. thanks!!
Old 04-10-2014, 12:17 AM
MUSTANGBRKR02's Avatar
Switching to a smaller pipe would help a bunch. Shouldn't be any problem spooling that turbo with that wheel with a 6.0.
Old 04-10-2014, 12:37 AM
which pipe would u suggest? 2", 2.25", 2.5"? what kind of increase spool time would i be looking at?
also by switching to a smaller pipe? would affect the higher rpm power range?
Old 04-10-2014, 01:16 AM
I am building a 427 with a 94mm turbo and going 2.5" Sch 10
Old 04-10-2014, 06:00 AM
Restricted User
JoeNova's Avatar
With a 76 You could run a 2" pipe without sacrificing any power. If it was a billet 76 you might want 2.25" just for some headroom, but you won't be needing it with the master power. I would drop to 2" and wrap the hot side. Your spool should pick up considerably.
Old 04-10-2014, 06:55 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
There is zero mechanical reason that you should be spooling that slow. It is ALL in the tune.
Old 04-10-2014, 07:18 AM
speedracer5532's Avatar
For your application I'd run 2" from the headers to the turbo.
Old 04-10-2014, 08:04 AM
71 chevy's Avatar
you are having trouble spooling a single 76 mm with a 6.0? something is VERY wrong.
also, how responsive are you looking for? i mean an NA 6.0 is freaking torquey even without a turbo.
if you want somewhere to start, look at timing, maybe looser converter, or if its just too slow- add nitrous.
good luck
Old 04-10-2014, 08:15 AM
Restricted User
JoeNova's Avatar
3" crossover is one mechanical reason. Thats a massive reduction in exhaust velocity, the exhaust is hitting the turbine slower. 3" crossover is usually used in 2200+ HP apps.
Old 04-10-2014, 08:44 AM
Ryans99ls1's Avatar
Even with 3" piping, it shouldnt spool that slow on a 6.0. It could probably fiixed by playing with timing/fuel during its transition into boost.
Old 04-10-2014, 08:54 AM
assuming the tune stayed the same...(i can change it, just using this situation as a base line) dropping to a 2" crossover, what could i expect in rpm for spool up?
Old 04-10-2014, 09:05 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
You could put a single nozzle pre turbine, that will definitely help it spool!
-Garrett
Old 04-10-2014, 09:08 AM
Rise of the Phoenix's Avatar
^^^ Money right there.
Old 04-10-2014, 09:09 AM
not looking to add nitrous at all. no offense...it is way to expensive to fill a bottle around here. almost 70 a bottle. no thanks.
Old 04-10-2014, 09:43 AM
7 Second Club
Phil99vette's Avatar
2.25" crossover pipe
advance the cam 4 degrees
Old 04-10-2014, 09:52 AM
123quattro's Avatar
I'm with most of the others. Something is more wrong than the piping size. It should be spooling 1000+ rpm sooner as is.
Old 04-10-2014, 09:57 AM
Blackpanther99's Avatar
This^^ Will definitely help the spool be a lot quicker.
Old 04-10-2014, 10:09 AM
necrocannibal's Avatar
Im running a billet 7675 on a 383 and it spools so quick it is ridiculous, even the shop that put it together was amazed at how fast it spooled. Im getting full boost well before you are probably low 3000, maybe even in the high 2000 range but I haven't really paid that much attention to know exactly.
Old 04-10-2014, 10:10 AM
I was thinking 2.25 aswell.
Old 04-10-2014, 10:14 AM
not saying it doesnt start to spool untill 4k...just saying i dont get full boost till 4000-4100rpm. although i would think it would be at full boost sooner.
Quick Reply: how can i get my turbo to spool faster?
