Turbo Auto Guys, Tire Height Question
Old 05-06-2014, 12:26 PM
HolyShiznit's Avatar
Default Turbo Auto Guys, Tire Height Question
Are most of you running 26's or 28's? I have a 3.42 rear, 4l60e, 3600SS stall. I already purchased 275/60/15 but after playing with calculators it seems my 3rd will be quite long. 153mph @ 6300rpm according to f-body.org/gears
Thinking of dropping down to 275/50/15's which would give me 142 @ 6300 and I of course could raise my RPM if I needed more MPH.
Its a 7475 Precision on a L33 with 317 heads and a Tick Stage 2 turbo cam running on pump.
Old 05-06-2014, 12:50 PM
67Firebird455's Avatar
That calculator doesn't seem to account for any converter slip, so definitely account for that. Depending on converter, I'm betting the 60 series is going to be a lot more on for what you're wanting to run through the traps.
Old 05-06-2014, 12:53 PM
Ryans99ls1's Avatar
Depends how much power you plan on making. you could creep up on 150mph traps with that L33
Old 05-06-2014, 12:57 PM
I plan on running 12-14 psi on regular pump no meth and adding more with some race gas for bigger street runs/track. Just don't want it to be too much of a dog on pump.
Old 05-06-2014, 02:13 PM
Photochop's Avatar
If you get a converter that works and want to leave in boost I'd go with a 28" tire, making your 3.42s more like a 3.23. It'll 60' better if the converter is working right on more tire.
Old 05-06-2014, 05:46 PM
JAX04's Avatar
This.
I have the Pro275 tires on my car, (not ran yet,soon) but that was one of the umpteen questions that Lane asked me when he spec'd my converter. PTC
Old 05-06-2014, 06:34 PM
Well my converter was not spec'd for me. It was an off the shelf Yank SS3600 that I picked up for a clearance type deal.
Old 05-06-2014, 09:01 PM
RonSSNova's Avatar
A taller tire will always hook better. More sidewall and more circumference.
I'll be running 30" radial slicks with 3.73 gears.
Ron
Old 05-07-2014, 07:50 AM
RedRocketZ28's Avatar
I ran a 28" tire with 3.25's last year. Have a 3.00 gear this year with the same tire. With the 3.25 I would hit fuel cut at 146 mph and trapped a best of 142 last year. My converter is a bit loose but helps to build boost at the line. Plus I don't want to spin my SBE much higher than the 6400 limiter. We will see how it does this year but I see a converter tightening in my future.
Old 05-07-2014, 08:04 AM
Man-Crush Warning
Shownomercy's Avatar
28s, 3.73s and a 6400 shift, seems to work well so far.
Old 05-07-2014, 08:11 AM
F110Mech's Avatar
maybe i should go with a 3.25 gear. I'm hoping to go 150+ shifting at 6500. I'm forged though so i can spin it higher through the traps if need be
Quick Reply: Turbo Auto Guys, Tire Height Question
