Expansion tank
Expansion tank
does anyone have a source for an affordable Expansion tank? like under $100 shipped affordable? Im unsure on the appropriate size to use and only want to do this once.
Ive read that the 1qt or 1/1/4 qrt is good but i wanted to hear from some of you that have used one. I found this one for cheap but am afraid it is too small..
http://www.racingpartdepot.com/servl...pansion/Detail
It, in itself, is not very large. however, That eliminates the remote fill, and i use a larger hidden overflow tank from there. the bottom outlet goes into the 1/2" npt heater port, the steam vents go to each side of it. If it overflows, it runs down to a large overflow tank under the core support, i have been considering running it to the trunk and putting a large clear container back there to measure it better, should it push water.
