my Nova getting after it with a junkyard 5.3
Old 05-19-2014, 08:13 PM
71 chevy's Avatar
Default my Nova getting after it with a junkyard 5.3
Im finally beginning to understand to the full extent the allure of these throwaway engines(the 5.3 to be exact)
my 5.7 developed low oil pressure and as it was being stored at my buddy's house we had no idea what the problem could be. assuming the worst I went to my source and picked up a $150 5.3 shortblock. actually, I picked up 2 for $300 just to have a backup lol.
it turned out that the 5.7 just spun two rod bearings and just needed a new crank and a couple of rods. by that time I already had the 5.3s so I put one in the car.
I sold the 24x/24x cam and put a different, smaller cam in it that is still about 10 degrees too big. I sold the 799 heads( Im not a fan), and put back the cheap, untouched 862 heads
so, my Nova GAINED 110lbs,
lost 1 full point of compression,
and lost about 30 cfm of head flow.
this little 5.3 did not get the memo. at the same exact boost level, it went a full 5 mph faster than the 5.7. at 8.8 psi the 5.7 went 116.92, the 5.3 went 121.8. I turned up the boost to 12.0 psi and the little engine that could surprised me with two new bests in the e.t department. I cant wait to see what it can do at 20 psi.
btw, to add a little fuel to the fire, hehe, Im running 1.875 primaries with 3" piping all the way to the turbo (1.32 s400 - the cheap one) at only 7.5% converter slip you can see it doesnt take very long at all to build launch boost and still be very efficient on the top end.
Old 05-19-2014, 09:07 PM
Wes Hardin's Avatar
how much does your car weigh
Old 05-19-2014, 09:19 PM
RonSSNova's Avatar
It's guys like you that make guys like me think I'm doing everything wrong.
Old 05-19-2014, 09:28 PM
NastyTBSS's Avatar
Kenadale!! Iv seen your car there before it's a beast!!
Old 05-19-2014, 09:29 PM
Vcious04's Avatar
Either your car weighs only 1500lbs or your boost gauge is waaaaaay off lol. Super fast none the less! Nice!!
Old 05-19-2014, 09:34 PM
71 chevy's Avatar
I wish I knew. Its not that heavy but its still a Nova, and the driver is 300 lbs in race gear.
I do know its gained right at 200 lbs in the last six months
Old 05-19-2014, 09:38 PM
71 chevy's Avatar
thanks man. you are doing everything right. youve been turbo ls for what, about 8 days now? and you are already running 10s. youre way ahead of the curve. it took me 4 years to get here lol.
Old 05-19-2014, 09:40 PM
71 chevy's Avatar
THANK YOU !!!
thanks. I have seen a boost gauge thats off before, like 10 psi lol, but I also have a fuel pressure gauge on the car and it rises 1:1 with boost so I know its not off. I wish my car was a super lightweight lol
I think because Im running methanol for my fuel and timing that would make anyone cringe is the reason for awesome times. the 4.86 gears help too.
Old 05-19-2014, 09:46 PM
Vcious04's Avatar
Originally Posted by 71 chevy
THANK YOU !!!
Very cool!! Are you Carbed? MS or gm PCM? How much timing under boost?
Old 05-19-2014, 09:51 PM
Chevymetal's Avatar
Nice man. That thing is a beast!
Old 05-19-2014, 10:00 PM
71 chevy's Avatar
Im running holley efi. at 12.0 psi, timing is 24.7 degrees. only because I run methanol as my only fuel. any non alcoholic fuel it would be a lot lower.
thanks man..
Old 05-19-2014, 10:19 PM
NastyTBSS's Avatar
Straight methanol? That's nuts!
Old 05-19-2014, 10:23 PM
71 chevy's Avatar
yep, straight methanol. belt drive fuel pump and 160lb injectors.
only thing is the engine never gets hot enough to boil the methanol out of the oil so I have to change the oil more frequently.
Old 05-19-2014, 10:31 PM
CROWN's Avatar
I'm saying the same thing!! That thing runs though OP. Maybe I'll run into you at the Dale one day.
Old 05-19-2014, 10:35 PM
Forcefed86's Avatar
That methanols some potent stuff... Lets people get away with all kinds of improper hotside dimensions...
I joke I joke, can't argue with results! Congrats, thats haulin the mail for sure!
Old 05-19-2014, 11:13 PM
71 chevy's Avatar
thanks. if you see me at the dale, please come say hi.I can talk about turbo ls for hours.
LMAO. I knew you would be the first one to read that and comment on it
hey now, methanol has only 8% the exhaust volume of gas but 3" piping has 225% the area of 2" piping
Old 05-19-2014, 11:35 PM
RonSSNova's Avatar
Hahaha,
Because I know you from the chevelle site I had to give you a hard time. Amazing setup you have.
I might be in diapers for a turbo guy, but they have a turbo logo on them. :-)
Old 05-19-2014, 11:47 PM
67Firebird455's Avatar
Holy crap that's quick! What's your 60' look like?!
Old 05-19-2014, 11:53 PM
71 chevy's Avatar
Hahaha,
hehe. them are some very quick diapers lol
thanks man. 60 ft on the 5.85 pass was 1.42
on the 5.71 pass 60 ft was 1.33
next time out im raising the 2 step rpm and launch boost. it will either spin the tires bad or s**t and get!
Old 05-19-2014, 11:54 PM
That's crazy man. What kind of front and rear suspension? I'm impressed! Amazed that lil 5.3 is able to hang like that!
Quick Reply: my Nova getting after it with a junkyard 5.3
