D1SC C6Z06 looking for +1200 on it
Hello there,
had a friend with D1SC 06 C6Z he just got a heads/cam looking before we installed them he thud that if we can sell the LS7 and get a LSX block instead of and build it for as much as he can boost on his D1 and adding a nitrous shoot on it, I thud it's a nice idea cause it's smilier to my project but there is few things are not the same such as his heads are Mast 285 and he's looking to get an 10-16 Psi on that D1 so he can enjoy this season with it, then he will upgrade to F1X, I find it awesome to build 2 great Z's, give me your recommendations who should build this engine and do you think it's will be good to spray with the D1? any pistons, crank and rods recommendations will be welcomed too.
Best,
Mubarak.
Best,
Mubarak.
LME or KUP 427 LSX
The MAST Heads are Fine.
Custom Cam from Martin @ Tick
Callies Ultra H Beams.
Wiseco Coated Pistons
Callies Dragonslayer
1/2 head studs
ARP bolts
Methanol Injection.
That should hold whatever you throw at it fairly easily.
As far as 1200rwhp the F1-X will do it alone. Plenty of people have sprayed boosted setups with a good tuner on board.
LME or KUP 427 LSX
1/2 head studs
ARP bolts
Methanol Injection.
1/2 head studs
ARP bolts
Methanol Injection.
Even more builders that don't need parts help from outside salesmen.
yeah have talked to william (H8RMKR) about his setup but he's look safer cause he's running an LS3 which is much better to hold that much of power than the LS7, we know about the F1X the guy thud if we enjoyed this season with the D1 then selling it will offer a good deal on F1X that's why he asked to stay with the D1 for this season.
LME or KUP 427 LSX
1/2 head studs
ARP bolts
Methanol Injection.
1/2 head studs
ARP bolts
Methanol Injection.
will try to contact them if you can get me the contact info's for them.
IMHO: BES, LME, BBRE, Steve Morris, ERL, etc. Are all good builders and will do perfectly fine.
First, the two he listed are perfectly fine. LME builds LMRs engines, and they run 6.80s. Also Kurt Urban was the first in the 6's along with Billy Briggs, Mark Carlyle's bullet was built by Kurt Urban, but also Kurt doesn't do anything but Dart Billet packages anymore. There are ton of good engine builders out there!
