3 Bar MAP connector issues
I bought the 3 bar MAP sensor most people run (12223861) and i cant connect it to my stock harness. I have the adapter harness but the key ways are wrong and wont let the two mate. My car is a 99 if it matters but im kind of stuck?
Adapter harness (female) on the left, stock MAP plug on the right (male). Notice how if i try to connect the two the slots wont let me?
I wouldnt be surprised if it was but im pretty sure i pulled this out of the MAP as i worked from the passenger side of the motor and the cam sensor more on the driver side. I am leaving the 2 bar in to seal up the hole so i didnt pull the actual sensor. I also havent pulled the intake because i dont have fuel rails (or a trans) in the car so i can reach behind and get to everything relatively easily. Once i get mad enough, ill pull the intake but i wasnt sure if anyone else had this issue
The thought has already crossed my mind, i was just trying to avoid it if i could haha. Thanks for the support on that so i dont feel bad when i end up doing it.
Thats actually encouraging. I wasnt sure if i just had some jacked up factory car. I ordered another adapter harness for $20, we'll see what happens
So i wanted to give an update to this. I bought this: http://www.bmotorsports.com/shop/pro...roducts_id/831
and it works. The funny thing is that all they did was cut out the slots/keyways in the plug i already had lol. its the exact same plug. Denmah strikes again!
So while i was trying not do things in a haggard way, it turns out i had no choice. In the end, I dont care as long as it works!
