How many guys ONLY run off the Wastegate spring
Old 06-24-2014, 04:58 AM
SPOOLED UP's Avatar
Default How many guys ONLY run off the Wastegate spring
without the use of a boost controller?
Just have a solid tune and let the wastegate, BOV do all the work!!!!!
Old 06-24-2014, 05:40 AM
yenkomike's Avatar
that's how mine is now . emusa 38 mm gate with the 2 springs 10# solid as a rock. it willstay for a while as my trans and axle need some upgrades before turning it up.
Old 06-24-2014, 07:23 AM
02LS1ram's Avatar
That's all I'm doing at the moment. I will add some sort of controller down the road but for now it's working. Just keep an eye on your gauges when driving, just incase you have boost spike, fueling problem. I'm sure some will say your crazy for not having a controller of some sort, but I'm not worried about it
Old 06-24-2014, 09:36 AM
willizm's Avatar
I ran an 8psi spring at first before getting a boost controller. No problems.
Old 06-24-2014, 11:13 AM
stevieturbo's Avatar
Nothing wrong with it if you are happy with a single boost pressure. It's probably the most simple and reliable option by far, and certainly the cheapest.
And there is a controller...the wastegate and spring/pressure signal technically are the controller
Old 06-24-2014, 11:23 AM
Troy5061's Avatar
I ran mine that way for a long time, I had it compressor housing referenced so with my 12psi spring it was only making 10.6psi at the intake. I got a controller so I could fine tune it.
Old 06-24-2014, 03:50 PM
mrstepheneades's Avatar
I ran on an 8psi spring for a while before getting a controller. No problems doing it only on spring pressure just get tired of the WEAK to easy lol.
Old 06-24-2014, 03:57 PM
Forcefed86's Avatar
I run WG spring pressure alone at the track. I have a ball valve in line with my EBC on the bottom port. I close it at the track and that nets me 20lbs. Open the valve and I slowly ramp in boost with RPM to 17lbs for street driving with the EBC. Works great!
Then I have another adjustable regulator mounted in the car that applies pressure to the top port to add above 20lbs if I want to break things.
Old 06-24-2014, 09:18 PM
3pedals's Avatar
Ive been running springs only as well, no controller.
I put 10 psi springs in for street, and 16psi for track.
Seems to work great, I have no need for a controller yet
Quick Reply: How many guys ONLY run off the Wastegate spring
