Any 4th gen f-body's run high mount a/c with a turbo setup
Old 08-07-2014, 12:21 AM
gols1go's Avatar
Default Any 4th gen f-body's run high mount a/c with a turbo setup
I was wondering if anyone had pulled off running a high mount a/c bracket to retain the a/c without using the low mount and running a turbo k member. I have seen the high mount alternator brackets for the passenger head, and I figured that the a/c line may need to be modded. Just a thought. Has it been done???
Something like these two pics is what I had in mind. I can run the Holley set for $260 which includes brackets for both sides.
Any 4th gen f-body's run high mount a/c with a turbo setup-ac_8.jpg
Any 4th gen f-body's run high mount a/c with a turbo setup-dsc00752.jpg
Old 08-07-2014, 04:15 PM
1bdbrd's Avatar
I have been wondering this as well. I am worried about the width between the strut towers though.
Old 08-07-2014, 04:27 PM
Ping King's Avatar
I have a setup I'm working on right now, the only way to package this nicely is to space the accessories out and use a smaller Sanden style compressor.
I'm going to run a truck spaced balancer, with F-Body accessories spaced the extra amount. If you look at all of the aftermarket serpentine setups for LS motors, they're all spaced pretty far off of the front of the engine.
With this way, you free up the space next to the block on the pass side, but you loose area in the front.
Old 03-31-2017, 08:14 AM
merim123's Avatar
bumping an old thread, I didn't find much on this and high mount setup. Ping King - did you make this work?
Old 03-31-2017, 10:29 AM
Ping King's Avatar
Had a baby and bought a house...lol nothing has been done.
Old 05-20-2018, 01:24 PM
guinness2's Avatar
I know this is an old thread but check this kit out from Holley https://www.holley.com/products/acce...s/parts/20-185
Old 05-20-2018, 07:20 PM
merim123's Avatar
11 3/32” spacing to passenger shock mount will definetly fit. When I measured stock it is around 14” if i recall (center of theottle body to first interference)
good find!
Old 05-20-2018, 07:40 PM
Ping King's Avatar
I've been look at this, but the budget doesn't fit right now. It's taken 2 years to do a clutch and bellhousing install.
Quick Reply: Any 4th gen f-body's run high mount a/c with a turbo setup
