Too big of fuel line?
Old 08-25-2014, 03:33 PM
Kc2006's Avatar
Default Too big of fuel line?
Have a question, and it may be dumb.
I have -10 supply and return lines already on my car, all the efi regulators I've looked at all have -6 fittings. Are -10 lines going to be too big? Is there a clean way to adapt them down to the -6? Only fittings I've found are male to male -6 to -10 fittings, of would I would need a -6 coupler also to adapt the first fitting to the fittings on the regulator. A -6 oring to -10 male would be awesome but I can't find any.
Any help on this.
Old 08-25-2014, 04:04 PM
stevieturbo's Avatar
Then try looking at regulators with larger fittings...there are no lack of them.
-10 lines are huge, and will support huge power levels, but no they wont pose any problems at sub 2000hp range either.
And you can buy fittings in virtually any size/configuration you'd ever want, or adapt them one way or another.
But you dont need to in the first place.
Old 08-25-2014, 04:49 PM
F110Mech's Avatar
I went -10 feed and -8 return and just found a regulator with those ports. It's overkill for my setup but it will be beaten into your head not to skimp on the fuel system haha
Old 08-25-2014, 04:58 PM
oscs's Avatar
Originally Posted by Kc2006
Have a question, and it may be dumb. I have -10 supply and return lines already on my car, all the efi regulators I've looked at all have -6 fittings. Are -10 lines going to be too big? Is there a clean way to adapt them down to the -6? Only fittings I've found are male to male -6 to -10 fittings, of would I would need a -6 coupler also to adapt the first fitting to the fittings on the regulator. A -6 oring to -10 male would be awesome but I can't find any. Any help on this.
No problem at all. I ran -10 feed -8 when I was N/A for over a year with no problems. The best bet is -6 straight cut with Viton o-ring to whatever size AN you need. I'll PM you where I get all mine from. They are cheap and ship fast.
Old 08-25-2014, 05:25 PM
68II's Avatar
Call up Orme brothers out of California, Joel there is great to deal with and can hook you up with anything you need.
Old 08-25-2014, 06:45 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Any help on this.
http://shop.brutespeed.com/Aeromotiv...tive-13110.htm
You'll have an easier time finding fittings for this regulator. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-25-2014, 07:02 PM
Kc2006's Avatar
Thanks everyone, the car had the -10 on it from when it was a blow thru set up. I was mostly worried that it would be too big since most regulators have -6 returns I freaked out.
Old 08-25-2014, 07:36 PM
Most regulators do not.
Some do, some dont, depends which one's you're looking at just.
Old 08-25-2014, 08:41 PM
Ls_Notch's Avatar
Never a bad thing to have too much volume
Quick Reply: Too big of fuel line?
