What is THE BIGGEST BADDEST T4 turbo on the market??
LS1Tech Sponsor
For biggest and baddest we have fit a PT88 (our optional 4" down pipe is direct bolt up to this) and a T4 S400 Borg Warner (requires simply a down pipe flange change on the 4" down pipe). In the BW we can do the 96mm turbine wheel on your choice of a/r for the housing matched with a Billet 76, 80, or 84mm ETR compressor wheel from FI. These all bolt up and clear the factory radiator in the factory position on our V2 kit
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
Yep, we have the optional 4" down pipe for the V2 kit. Standard with a PT88 flange but a simple flange swap and a BW S400 T4 will bolt up! These will also bolt up and clear the factory radiator in the factory position also!
__________________
LS1Tech Sponsor
Nope, would want more. Asking a lot out of a little T4 but we are seeing what we can come up with to fit our kit and meet his goals for a turbo
__________________
PT88 wont make 1300 Flywheel..
Call Jose and ask him to build you a copy of Mike Jovanis's turbo. Its the only way you are gonna hit 1300+ rear wheel horsepower with a T4 based unit.
I honestly dont understand the T4 requirement for this. Just do it in T6 and be done and it will be easier and Cheaper to do.... If everything is done correctly the T6 should spool just fine.
