"The Bad Idea" Twin T70 On3, L33, glide', MS3 "vette" build.
Old 03-24-2016, 06:39 AM
  #61
black06g85's Avatar
damn so much awesome.
can honestly say that's the first time I've ever wanted a chevette lol.
Old 03-24-2016, 10:15 AM
  #62
spray280's Avatar
Awesome build!! Great idea extending the pickup tube, should work well.
Old 03-24-2016, 01:14 PM
  #63
Bad Apache's Avatar
You sick F'er, I love it!
Old 03-24-2016, 01:45 PM
  #64
CJ Hungus's Avatar
Old 03-24-2016, 06:22 PM
  #65
Turbo D's Avatar
Originally Posted by 98Camarod
Nice work! What's holding down the second rail?
The upper second rail bolts to the first rail and that bolts to the intake, I did that after the pic was taken, it was the only way that I would be able to get everything apart easily, I'm going to be running it on E98 to start and switching to methanol later on.
Old 03-24-2016, 06:50 PM
  #66
a4ls2goat's Avatar
badass build.
are you going for the SBE record
Old 03-24-2016, 08:41 PM
  #67
Turbo D's Avatar
I'm not really going for anything right now other then getting it making passes. It's been alot of work so far, we'll see what it does when I get to that point.
Old 03-26-2016, 11:14 PM
  #68
Busa_rob's Avatar
Awesome build. Makes me want one.
Old 03-27-2016, 08:57 AM
  #69
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Impressive solutions to common problems! Loving it.
Old 03-28-2016, 08:22 PM
  #70
ringgold's Avatar
My mom had a Chevette when I was a kid. One day it popped out of gear while sitting in the driveway. My mom hadn't put on the parking brake, so it took off rolling down our backyard, through our picnic table , and finally parking itself in the side of our storage shed down in the yard. My dad was pissed!!! had to rebuild half the storage shed.
Like mentioned many times, awesome build man!!!!
Old 03-31-2016, 12:57 AM
  #71
Turbo D's Avatar
Few more updates, got the coils mounted on the side of the block, stock style long LS plug wires will work with where they are mounted.
Bolted up the midplate, water pump, built my own steam vent kit out of 1/4" Push to connect air brake fittings and line.
Got my new turbo's in, these are a 72mm compressor 68mm turbine wheel with a .81 t4 exhaust housing. Pretty much a direct knock off of a Turbonetics Sylvia turbo, they seem like they are really well made.
Dropped the engine in, Painted and wrapped the hotside, mounted the turbos to see if everything was still where it needed to be. Also mounted a small battery on what was left of the passenger side firewall shelf, it's a 20lb lawn and garden battery rated at 450 cranking amps.
My wheel tubs showed up for the back, so I'll be switch back into sheetmetal mode this weekend, more updates soon, thanks for looking.
Old 03-31-2016, 06:30 AM
  #72
Tomhames's Avatar
Crazy build man! Can't wait to see it go down the track.....
Can you post a link to where you got the turbos from?
Thanks in advance,
Tom
Old 03-31-2016, 06:46 AM
  #73
Guard dog's Avatar
So much awesome in such a small package.
Old 03-31-2016, 09:20 AM
  #74
Forcefed86's Avatar
Lookin good! Are those the Rev9 turbos for $239?
http://www.ebay.com/itm/Rev9-Typhoon...dV6hUE&vxp=mtr
Old 03-31-2016, 11:18 AM
  #75
Turbo D's Avatar
Same seller, but not the same turbo, I saw those ones too but I didn't want a divided exhaust housing with the way my turbo kit is designed. These are the ones I used. http://www.ebay.com/itm/351475468245?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 03-31-2016, 09:36 PM
  #76
Tomhames's Avatar
Thankyou!
Keep at it....
Old 04-02-2016, 10:24 PM
  #77
vht
vht's Avatar
I was told you could run the twin scroll on a open flange. Very nice build, can't wait to see what she does. Any HP goals?
Old 04-03-2016, 01:12 AM
  #78
Turbo D's Avatar
You can, but I made these logs with round hole type t4 flanges so I think it would cause a restriction with a divided housing. I hope to baseline it around 7-800rwhp and just tune it from there at the track. I have it geared for around 180mph, but we will see when I get to that point, the car will be a handful I'm sure but I enjoy the challenge.
Old 04-07-2016, 09:04 PM
  #79
vht
vht's Avatar
I can't wait to see some ets. This is going to be Bad A$$.
Old 04-23-2016, 12:21 AM
  #80
Turbo D's Avatar
Another update, been plugging away on wiring and other things, just about have it ready to fire, just waiting on a few small things before i can. Bought a cheap B&M bandit knock off shifter for the car but I wanted the MS3pro to shift it so I bought a $15 air cylinder and welded a tab to the shifter.
Got the wheel tubs in, first time I've ever done aluminum tin work it worked out pretty well so far, still need to do the rest of the interior.
Took the car to get the Chassis certed last Saturday, Passed with flying colors, good for 6.0 in the 1/4 under 2800lbs.
My little trailer that I pull this or my Pinto around on. Doesn't take much to haul a 1900lb car.Name:  IMG_1470.jpg
Quick Reply: "The Bad Idea" Twin T70 On3, L33, glide', MS3 "vette" build.
