408 w/billet FI S484/96, BR7 or BR8's with 20 psi?
Finishing up my new setup up and was just wondering what you all would recommend as far plug and gap... setup is a iron 408 with PRC LS3 260 heads, 10:1 compression, billet FI S484/96, going to run around 20 psi i'm thinking all said and done, will be using 104 and two nozzles of 100% meth for now.... BR7's at .22???
B style, R resisted. Number=heat range (higher being colder) and P is protruding tip
P's may be an import thing though-
So a BPR8ES is a Protruded, Resisted 8 heat range plug
BR8ES is the same plug non protruded
B8ES is non protruded, non Resisted
BES is a pile of parts.
To the OP, ask and trust your tuner.
there is no BR8EFS..
Resistor plugs stop at heat range 7....
only way to tell if you need a 7 or an 8 is to start to push it and read the plugs
check for a timing mark, and see if you are turning more than one or two threads a different color
if the plug doesnt show any heat on it... then a 7 is fine....
Just for reference... lots of cars running Br7efs plugs on 15-20 psi with no issues
if you have to go to an 8... but the NGK resistor boot's to put on your plug wires.
I believe the "R" can also indicate recessed? Not always resisted?
I think you are correct if we are talking strictly about a conical seal plug.
I have heard of many running a gasket type seal plug on a conical LS head with no problems. Some say they seal better.
If this is the case an NGK BCR8ES (5430) would be a resisted 8 heat range plug.
http://www.motorcyclesparkplugs.com/...l#.VISssjG6Pbc
Rock auto sells them for $2.60 a plug.
