Truck manifolds *Pic*
Hey guys,
I've been scratching my head for a bit trying to figure out which way I want to go with Turbo headers. I trip over these stock manifolds every day in the garage and finally got to looking at them (as I was about to throw them away.)
After googling them for a bit it appears these may be the ones that are being used as the manifolds for the Turbo swaps. Can anyone confirm?
Hey guys, I've been scratching my head for a bit trying to figure out which way I want to go with Turbo headers. I trip over these stock manifolds every day in the garage and finally got to looking at them (as I was about to throw them away.) After googling them for a bit it appears these may be the ones that are being used as the manifolds for the Turbo swaps. Can anyone confirm?
Also, does anyone have a link to someone that offers the Manifold flanges for building a hot side off these manifolds? I think I found one place while searching but I thought it would be a common part.
So I finally got these things all media blasted and painted up. I mocked them up to see how they went and something doesn't seem right.
The passenger side seems to be just want I want. The drivers side on the other hand will never work with this crazy height. I can't flip it to run out the back because I'll have to run the crossover all the way around the car.
Is it normal for people to use 2 Passenger side Manifolds? I know it doesn't really matter and everyone's situation is different. I think it will make the Drivers side a better fitment for when I fab up the hot side. Here's a picture of the Passenger side flipped facing down on the drivers side.
Yea, yours are off a 2003-05 SSR LH6/LS2 or TBSS from what i can find.
Deff looks longer.
Mine are
GM 12571680 (driver)
GM 12578342 (pass)
Also have a set of
GM 12616287 (driver)
GM 12616288 (pass)
both appear identical.
Deff looks longer.
Mine are
GM 12578342 (pass)
Also have a set of
GM 12616288 (pass)
There are many variants of manifold (some stamped steel even) that came on the trucks. You just have one from a different truck than the standard 01-up cast 5.3/4.8 junk. It looks like it will flow great though! Just log those off, weld v-bands on and go to work.
FYI there are no "stamped steel" truck manifolds. That is a myth,They are all cast iron. I did chemical tests on a few sets a while ago and they where all the same. For some odd reason they seem to weld great regardless of what the test results showed. I think the higher levels of silica contribute to that.
Streetracer, I have these for sale if you're interested. I'm in northeast Md and could meet you somewhere if you're interested.
https://ls1tech.com/forums/eastern-c...ds-vbands.html
