kit like APS or CAS?
Hello everyone, i want to turbo my 02 ws6. I do not want to remove front plate or fogs. Kinda want a "stealth" set up. I have seen pic of the cas and aps systems, and it looks like they fit in the engine bay as is. Does or can anyone make a similar system? If so who? Thanks for your input everyone!
Bruce
Bruce
Oh, i think Modular turbo? IF that was their name made a kit that was supposed to be bolt on and didnt have to modify anything?? Its been a few years and i think they only sold a few, not sure if they still are or not, look them up on here...i cannot remember the name of the guys who built them...
It appears they are no longer a vendor here.. NOt sure if they still do them or not...
https://ls1tech.com/forums/forced-in...turbo-kit.html
Thats the reason i liked the aps kit. as far as the a2w intercooler ; after hours of searching, i still really dont get how to mount the a2w intercooler. i get the remote reservoir, and i need a heat exchanger. But thats as far my knowledge goes. How would i go about mounting 1 w/o cutting up the car? Anyone got pics of theirs?
There really aren't too many places to mount a heat exchanger on a 4th gen car if you're going to make the nose off limits.
I can only think of 3 good places.
1. in the air stream ahead of the radiator. Problem is you're now dumping hot air onto the radiator and/or ac condenser
2. between the front frame rails using a scoop. Problem is you have to pick up air from below the air dam which funnels air into the radiator so it hangs really low and also channels air up into the engine bay
3. mount two smaller heat exchangers in the splash panels similar to the procharger dual intercooler setup. Problem is you're adding even more complexity to the system and more fluid (weight)
All three would probably need fans added to them as well.
As far as the a2w core itself you could have one built that would fit where the battery/overflow sit without too much trouble. Just use a smaller reservoir and move the battery to the rear.
Op, anything can be made, you would need exact dimensions for it to be correct, though. There is a guy on Facebook selling an APS kit with upgraded turbos for cheap. I could track him down if you're serious.
It's a shame the CBR kit didn't get as much interest selling as it did when they took the time to ask the guys here what they wanted to see in the kit. If CBR could have made a few more kits in the beginning it would have helped guys like you out. I was lucky enough to get in while they still had one and what it has done is perform exactly like it was suppose to. Without question the most inclusive, well built twin kit, ever made for these cars.
