Holley HP EFI no start
Old 01-01-2015, 09:16 PM
BUDGETRAT's Avatar
Default Holley HP EFI no start
Need help figuring out why I have no spark on 09 6.0. I'm new to the Holley EFI. I've checked all grounds and swapped crank sensors but it shows no rpm when cranking. It has shown it a split second a couple times but generally when cranking it shows syncing. I have latest firmware in ECM and have tried different tunes just to see if it changed anything. Also I have the LS2 harness and setup for 58x crank. Thanks for any help
Old 01-01-2015, 09:55 PM
Hi-Po's Avatar
Start here.
http://forums.holley.com/showthread....ist-Holley-EFI
Old 01-01-2015, 09:58 PM
Beanslsxnova's Avatar
Have you done the tps autoset. It will not fire or signal the injectors untill you set up the tps
Old 01-01-2015, 10:21 PM
BUDGETRAT's Avatar
Originally Posted by Hi-Po
Thanks I will check all these
BUDGETRAT's Avatar
Yes I did do this Thanks
Old 01-02-2015, 05:52 AM
forcd ind's Avatar
When you first turn the ign on, do you get all sensors sync.
what tune up did you load
as said, TPS autoset
go back thru all your settings, double ck they match your engine
Old 01-02-2015, 06:04 AM
Hellhaunter's Avatar
i would check the harness to see if it's wired correctly ,the diagram is in the manual or on Holleys site
i have read some posts that holley have had faulty connectors.
Old 01-02-2015, 08:01 AM
samdogmx's Avatar
It has to see a valad RPM when cranking.
Check the crank sensor, make sure its the correct one for 58x, check the harness, check you have it set right in ignition parameters.
Old 01-02-2015, 08:40 AM
BUDGETRAT's Avatar
Its the gray (58x) crank sensor I swapped it with another known good one and tune is set on 58x Thanks I'll ck connector tonight. I don't think your to far from me I'm about 50mi west of STL.
Old 01-02-2015, 08:51 AM
BUDGETRAT's Avatar
The two time it did show rpm for a second I had just got done syncing ECM not sure if that was coincidence or not
Old 01-02-2015, 09:01 AM
samdogmx's Avatar
Id start by double checking the wires where they go into the plug at the crank sensor, make sure nothing is loose, then OHM each wire from the crank plug back to the main connector on the holley.
Old 01-02-2015, 12:41 PM
BUDGETRAT's Avatar
ok I'll do that tonight. Thanks again!!
Old 01-02-2015, 02:14 PM
toytech93's Avatar
Does the system prime the fuel pump when you first turn the key on ?
Check to make sure the red wire for the engine harness has power while key-on/engine cranking. Most lose power while cranking.
Old 01-02-2015, 03:47 PM
BUDGETRAT's Avatar
It does prime I'll double ck red wire though
Old 01-03-2015, 05:09 PM
BUDGETRAT's Avatar
Got it to run !!!! Was dropping battery voltage gonna get a new bigger battery since it's in trunk. Thanks everyone!! Now just have to get it to idle
Quick Reply: Holley HP EFI no start
