LS Swapped 408 Billet ETR-HO S484 Toyota Tacoma makes 1050rwhp
Old 01-02-2015, 10:11 AM
Sales@Tick's Avatar
Default LS Swapped 408 Billet ETR-HO S484 Toyota Tacoma makes 1050rwhp
I have had the opportunity to work with our customer Travis for well over a year and a half now. Helping him with choosing the best parts for his budget and giving him good advice regarding the build of his truck. Travis lives in Jacksonville, Florida which is a good 8 hours drive from our shop. He had an issue with a tuner when this truck had a 370 c.i. motor and busted up a few ring lands because of detonation from unsafe, and quite frankly poor tuning.
To protect his new investment he made in a very nice 408 he had built after the 370 let go, he made the long haul all the way from Jacksonville to Mount Airy, NC for us to tune his truck. Edward Miller of "The Engine Works" built his 408 for him and you may know or recognize Ed's name from his winning Drag Week Plymouth Duster he campaigns. Needless to say, Ed builds one heck of an engine!
When Travis brought us his truck, he didn't have an air filter on the inlet. During the initial tuning session, we noticed at the end of a pull that the boost was dropping badly. Upon inspection we realized a foreign object made its way into the compressor wheel damaging it badly. We told Travis we would give him our cost on a new compressor wheel as it happened on our watch even though we can't really determine what went through the turbo.
Travis took this opportunity to upgrade from his S480 cast wheel unit to the new ETR-HO S484 that everyone has been raving about lately. Unfortunately it was found that Travis turbo was not what he was told it was when he purchased it used. The original owner told him it was a T6, 1.32 housing 96mm unit, but in reality it was a T6, 1.10 housing 83mm unit. So Travis had us upgrade that as well to the 96mm wheel and 1.32 housing that this engine really needs to make the power Travis wanted.
Once we got the turbo back we fabricated a nice little mesh screen that Travis supplied to go over the inlet so no more accidents could happen. We just wrapped up tuning after maxing out a set of 1000cc injectors at well over 80psi fuel pressure.
Quick run down of the engine combo:
Iron block 6.0
4.030" bore
6.125" rod
4.0" stroke
9:1 CR
AFR 230cc cylinder heads
Edelbrock Pro Flo intake
237/241 .640/.630 116lsa camshaft
FTI TH400
Yota rear end
Forced Inductions S484 billet 1.32 housing 96mm turbine wheel
4" downpipe into 4" electric cut-out which is open for these pulls
23psi, 21* timing on C16, B9EFS plug being read after every pull with load:
Remember this is through a TH400(unlocked) and a unknown Yota rear end. From what I've heard these Yota rear ends are not the best when it comes to parasitic losses, but oh well.
Converter is super loose as you can see it stretches it way out. If it were tighter we'd probably see a lot higher torque numbers.
Truck was spinning badly on the rollers, so we had to put some bodies in the bed! Enjoy!
Old 01-02-2015, 11:13 AM
Ratical's Avatar
Nice numbers.
Why do I seem to see so many people going with the 400+ ci engines and the S484? I used to read that 1.32 housing and .96 wheel would run out of breath too quickly with it but they seem to run strong and this engine still seems to be pulling strong at almost 7k rpm.
Old 01-02-2015, 12:06 PM
Sales@Tick's Avatar
Originally Posted by Ratical
Nice numbers.
The compressor also plays a large part, not just the turbine wheel.
This compressor has a very broad compressor map at higher airflow rates at lower pressure ratios where larger 4" stroke based engines will operate in a street driven application.
Making it a very good match for a street vehicle that operates around or under 7k with 370-408 c.i.
This turbo is a bit too small IMO for anything much larger than a 408, but if someone didn't mind spinning 6000-6500rpm with a 416-427 c.i. IMO it would also work well.
Old 01-02-2015, 12:15 PM
turbo6man's Avatar
Wow that's killer. The dyno pulls were with the screen on the compressor housing? That is nice if it was because I hear so many people saying you cannot put a screen on because it will restrict it. Are you going to start selling those screens because I have an s484 and would order one today.
Old 01-02-2015, 12:44 PM
Rise of the Phoenix's Avatar
That's just crazy. Pretty cool seeing this in a Toyota pickup. I bet that thing will be leaving people scratching their heads.
Old 01-02-2015, 12:51 PM
Ratical's Avatar
Ah ok. Well they definitely seem to work! That Taco must be a blast to drive!
Old 01-02-2015, 01:11 PM
831jd's Avatar
You think a 383 stroker would be more efficient with the s484?
Old 01-02-2015, 02:33 PM
Sales@Tick's Avatar
It did have the screen on it. It would be very interesting to see how much power it was robbing, but after the first mishap, we're not chancing it with this one again.
Jonathan said he went out to test drive it on the street. On the 13psi pump gas tune that makes 800rwhp the truck is just ridiculous to drive.
It is outrageous and is literally a spin machine. Couldn't even get a decent data log because it was spinning so badly.
I do think it would be a little more efficient, as the sweet spot for this turbo seems to be 375"-400" engines.
Old 01-03-2015, 02:14 AM
95bowtie's Avatar
Turbo guard makes a really nice screen that is molded into the rubber that clamps onto the inlet. They are like 25 bucks and come in every size you can think.
It really isnt a mesh screen that most ppl rig up, the holes are larger and it seems like it would have no restriction at all. Still yet it will keep out those small pebbles that are always on the roads that your tires like to kick up.
Old 01-04-2015, 12:56 AM
my first ls1's Avatar
How much more does this setup have in it with larger injectors?
Old 01-05-2015, 01:06 PM
Sales@Tick's Avatar
If this truck had an aftermarket block with 6 bolt heads and parts strong enough to hold it, I have no doubts that we'd hit 1200-1250rwhp before the turbo started to show signs of running out of steam.
Old 03-14-2015, 03:36 PM
hotrodth's Avatar
Thanks for sharing it martin. Truck is a blast to drive. Still havent turned up the wick yet.
Old 03-14-2015, 04:33 PM
SSZ
SSZ's Avatar
Man who would think a Toyota truck would be packing heat like that.
Killer sleeper if you ask me.
Old 03-14-2015, 04:53 PM
madmike9396's Avatar
Absolutely Bad *** !!!
Quick Reply: LS Swapped 408 Billet ETR-HO S484 Toyota Tacoma makes 1050rwhp
