New 85 and 88mm S400 Borg turbos are here!!
The new 85 and 88mm S400 Borg Warner turbos from Forced Inductions are here. Preorders are being taken if you are interested.... Pricing for these units will be 1799 and are available in the V2 cover only. Currently there isn't an ETA on the production units arriving.
These wheels only need to be ran with the 96mm turbine. You have options for the turbine housing just like the other compressors.... 1.10/ 1.32/ 1.58 in T6 and 1.00/1.10/1.25 in T4
Borg warner has made the 410 V2 Race cover available ala carte now so i can do these new 85 and 88mm wheels on a 400 chassis as well as the 410.... The wheels are specific to this cover.
Ok so 88mm is the size of the compressor wheel while 96mm would be the turbine wheel (this is just an example) which would make it a 88/96 combination am I on the right track here ?
If you are trying to crossover to precision nomenclature... these units would be 8588's. And 8888's.
