2000+hp CTS-V build LOTS OF PICS
The goal is to run high 7s @ mid 170mph in the 1/4 and my wife still be able to pick my son up from school and drive the car to work on nice days. We will be keeping A/C, heat and all the other comforts that the cts-v has to offer. We are hopping to have the build done in Feb if all goes well thats a big if.
So here are some of the spec's
MOTOR FROM Total Engine Concepts
LSX block
crank callies magnum
9.34 CR
coated main & rod bearings
ARP stud kit 1/2
RHS LS7 heads
Jesel rocker arms
Custom cam
Custom push rods
Morel oil pump
ECM FROM ProEFI
ProEFI 128 with all the good stuff
INTAKE
Holly high ram
INJECTORS
ID 2000
CUSTOM TOP MOUNT TURBO KIT FROM GEARHEAD FAB
Twin precision 6870BB turbos
Custom A2W intercooler
10 POINT CAGE FROM GEARHEAD FAB
12' parachute
FUEL SYSTEM
Fore in tank with -10 fead and -8 return with the biggest pumps you can get.
TRANS FROM ATF SPEED
TH400 with trans brake stage 4 with 4000 stall
REAR FROM GFORCE1320
9" center with drive shaft shop axles
WHEELS
Weld 15" beadlock rear
Weld 17" fronts
Rear 15" brake kit
This is what I have for now I will keep this up to date as the builder sends me lots of pic all most daily. Please feel free to comment and ask questions.
LSX block
9.34 CR
ARP stud kit 1/2
RHS LS7 heads
Jesel rocker arms
Custom cam
Custom push rods
Morel oil pump
ECM FROM ProEFI
INTAKE
Holly high ram
INJECTORS
ID 2000
12' parachute
FUEL SYSTEM
WHEELS
Weld 17" fronts
Rear 15" brake kit
Thanks guy's. I will have the motor the end of the month then we can get the hot side going. He will be mucking up the rad and intercooler as soon as we get the cores. The motor is being built to handle 2500hp but Im going to run out of turbo before then, we will see what these new 6870 will make.
It sure would be nice to be able to run 7/8s without having Cage up such a nice car.... but safety is safety.
Are you going to retain stock belts plus have harness' I assume?
We will be keeping the stock belts and adding the harness. As far as the cage he keep it so tight you can keep card's in between it and the car. You can't even see it really from the out side.
