4.8 twin turbo or single turbo
Getting some opinions. I'm looking to achieve 500 reliable hp. I have plenty of space as it is going into a custom tube framed car.
My question is would you do single turbo or twins.
What size injectors would you run to run 10-12psi? 80s?
The car will be a street car mostly. It will not weigh much so a ton of power is not needed. Guessing it'll end up around 2,000-2,500.
The budget is not set per say. I plan to build the car and engine over the next year or so. I have been acquiring parts lately. Motor, t56, suspension components, etc. I'd like to be reasonable though.
For that low of a power level on the street, I see no real reason to go twins. Like I mentioned earlier, an affordable box unit s366 would fit the bill nicely. Might even be a little big. Depending on your budget you could have somethign spec'd to fit the bill exactly or go that route.
Jack
Jack
I have no desire to chase NA levels that high especially because I already have the 4.8 with low miles. I know these motors aRe stout. I guess I lean towards twins for the fact of it being a v8.
Restricted User
When even a single eBay turbo can make that power on a bone stock 4.8, it's hard to justify twins....
There seems to be so much love for the bigger displacement motors. Don't get me wrong a NA 6.0 fully built would be awesome. But there is something about taking a junk yard 4.8 and making the same power barely built at all with a turbo. Not to meantion that beautiful whine a turbo makes.
That said...my friend is building an all out high stall trans brake TH400 mud drag truck with a 4.8 and twins...going to be a blast!!!
Especially because I bought a 4.8 motor for $500 and the guy through in a 4l80e with converter. I am selling the trans to a guy Friday for $400. $100 for a complete ls style motor seems like a good start to me. Bought a truck harness and 0411 ecu for $75. Complete running engine for $175.
I guess that depends on the size of the engine...it was easy in my LS3 Camaro. AI 275 CC heads, custom grind cam, good headers and good tuning...466 rwtq and 500 rwhp. Cost a lot less than a turbo...I've seen a lot of people claiming 500rwhp cam only on the LS3 platform...but I don't buy the numbers...and several of them that I've run into watched me pull away like I had 20-30 hp on them every time.
I have a stock bottom end LS1, and if I hadn't been able to do all the work myself (porting/milling heads and building a manifold) I'd already be well beyond the price tag of a huron speed turbo kit by now with a good set of heads and fast 102/tb, headers, cam/springs/stainless valves, longtubes, injectors, fuel rails, flycutting pistons, etc etc.
And at 500whp I'll be pretty much done N/A. An affordable turbo kit even on a bone stock motor would support 650+. It's all about your goals and priorities.
Jack
Happy dynos....
Jack
Jack
