ProCharger C6 Stage 11 Direct Drive System
Old 02-19-2015, 10:21 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Default ProCharger C6 Stage 11 Direct Drive System
http://shop.brutespeed.com/ATI-1GP20...1GP202-SCI.htm
http://shop.brutespeed.com/ATI-1GQ30...I-07-13-C6.htm
http://shop.brutespeed.com/ATI-1GQ31...I-07-13-C6.htm
Check out the new ProCharger Direct Drive System at the above links. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-19-2015, 01:40 PM
Mike Farris's Avatar
Procharger stepping up their game.
I like the spring loaded tensioner better than the alternative manual tensioners. Any price yet on the direct drive? Need this and the new cooler.
Old 02-19-2015, 01:48 PM
LS1Tech Sponsor
Hi Mike, I should have a price on the direct drive shortly. I'll post it here asap. Thanks. Bob
__________________
Old 02-19-2015, 02:33 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Hmmm, wonder if that could be modified to work on an F-body...
Old 02-19-2015, 05:28 PM
Detoxx03's Avatar
Glad they came out with this cause I was looking at other companies that make them. Gonna have to look into this further if the price is right.
Old 02-19-2015, 06:26 PM
conan's Avatar
I'm confused, does the original Procharger set up in the C6's run off the main serpentine belt system ?
Old 02-19-2015, 06:47 PM
LS1Tech Sponsor
Yes it does. Bob
__________________
Old 02-19-2015, 06:52 PM
conan's Avatar
Originally Posted by Bob@BruteSpeed
Yes it does. Bob
Guess I assumed all Procharger setups had their own drive belt like the F-body.
Old 02-19-2015, 10:32 PM
94 slow's Avatar
Bob,
Does the new direct drive system move the blower inboard(closer to the motor)?
Old 02-19-2015, 11:25 PM
neverstop's Avatar
more competition is always good but all this that I've been hearing about belt slip on the alternator causing lack of voltage/amps at high rpm and messing up the fuel systems makes me scared of these things.
Old 02-20-2015, 07:28 AM
Realcanuk's Avatar
Buddy............guys been running them for years with praise. This voltage drop thing seems to be flavor of the month for some reason.
Old 02-20-2015, 10:42 AM
Unreal's Avatar
Voltage drop is very real. I don't know anyone locally running a DD with alternator issues. Once the belt gets worn at all, it starts squealing and slipping, especially at high RPM.
I wonder how they are getting around carteks patents? The reason all the others got pulled from the market was cartek got the IP.
Old 02-20-2015, 01:21 PM
chpmnsws6's Avatar
I wonder if Gates makes a fleet runner belt of that size. I have an 8 rib for my blown C6 and it GRIPS. If they add an extra pulley on the top side of the belt like the C5 has, they might get enough wrap on the 4 rib.
Old 02-21-2015, 06:57 AM
LS1Tech Sponsor
Many of them don't, such as the GM truck kits. Bob
__________________
Old 02-21-2015, 06:58 AM
LS1Tech Sponsor
Originally Posted by 94 slow
Bob,
From what I found out, it doesn't. I was told the accessories are first driven by the a/c belt, then it transfers to the rest of the accessories via an intermediate dual-rib drive pulley. Thanks. Bob
__________________
Old 02-21-2015, 07:01 AM
LS1Tech Sponsor
ProCharger also made sure that the accessories were given a strong OEM spring loaded tensioner. Using a spring loaded tensioner ensures that the accessories will have the proper belt pressure applied to them as the belt wears and grows over time.
Bob
__________________
Old 02-22-2015, 01:09 PM
Firehawk441's Avatar
Why would you want to do that?
Old 02-22-2015, 02:13 PM
94 slow's Avatar
Bob,
If I was going to retro fit this system into another vehicle, and I was not going to run a/c, is there another pulley I could bolt on in place of the a/c unit?
Old 02-23-2015, 06:32 AM
UNDER PRESSURE MOD
It looks like it would allow for more room for a larger blower by mounting it up high like that. I know there have been a couple guys who've mounted bigger blowers (f-series) up there.
Also because it's something different. Never hurts to have options.
Old 02-23-2015, 06:48 AM
chuntington101's Avatar
Bob, is there any risk of the water pump slipping at higher engine speeds? the belt wrap around the water pump seems minimal at best.
Quick Reply: ProCharger C6 Stage 11 Direct Drive System
