454 LSX forced induction
Old 02-26-2015, 01:07 AM
mohd2116's Avatar
Smile 454 LSX forced induction
dears ,, i have 454 LSX stock with LS7 heads and actually planning to go for twin turbo but i'm looking for the recommended brand and size because this is the first time to work on force induction .
i need expert advice !!
Old 02-26-2015, 11:31 AM
stevieturbo's Avatar
And are you looking for 50hp, or 5000hp ?
Old 02-26-2015, 02:36 PM
Meth Sled's Avatar
X2
And also, what's the purpose of this motor and car? Strip, street?
Old 02-27-2015, 04:47 PM
6togo's Avatar
I would not plan on throwing much boost at it those cyl. walls are fairly thin!
Old 02-28-2015, 12:30 AM
rkreigh's Avatar
feel free to post more about intended use and budget
for up to around 1200 hp, a reasonably affordable small bore iron block can make plenty of power and work better at a much lower cost
or if you want more the LS next and other alternatives such as a built RHS can be needed as you want more
based on your post, I'd say you got some splainin to do to get any expert advice
Old 03-18-2015, 06:10 PM
mohd2116's Avatar
Default 1200hp
Actually yes planning to reach 1200HP what should I need for that !!
No budget limit on this stage I just make my study for my car ,, the purpose it will be street racing car
Old 03-18-2015, 07:17 PM
busa3268's Avatar
Don't tell Nelson racing engines that.
Old 03-19-2015, 05:11 PM
Unreal's Avatar
The GM LS454 isn't a good boost motor. Much better off starting with a different setup.
Old 03-20-2015, 05:43 PM
LS6427's Avatar
LOL.....No kidding......Nelson's 454ci LSX makes 2,500 HP.....all day long. And will last a long time. Just gotta be built properly....
Old 03-20-2015, 06:09 PM
Unreal's Avatar
HUGE DIFFERENCE in price between Nelson and GMPP motors. Not even on same level.
Old 03-20-2015, 06:40 PM
6togo's Avatar
He uses Tall deck blocks for the builds also!
Old 03-25-2015, 09:46 PM
6 Second Club Moderator
LASTLS1's Avatar
I've heard a lot about Nelson's engines. Never heard of one wining a race at the track,,, and I race a lot. Who has one in their car that races? Just curious.
Old 03-25-2015, 10:12 PM
Detoxx03's Avatar
I would not use that block for forced induction.
Old 03-26-2015, 04:40 AM
Heavy H.P.'s Avatar
Whats good cubic inches to go with using a LSX block for a setup that will make over 1000hp to the ground and will be ran at the track and on the street often?
Old 03-26-2015, 08:50 AM
Restricted User
JoeNova's Avatar
Don't go crazy on bore size. With boost, you don't need lots of cubes for good power. There are lots of 1200+ hp street cars running on 3 liters. Cylinder wall thickness helps give a block rigidity. This is why there are a several 4.8/5.3 OEM blocks making over 1000 HP on the street without block failure. The cylinder walls have serious meat between them.
Old 03-26-2015, 10:37 AM
blaine123's Avatar
Well you can, but you have to keep the boost fairly low. I think under 10 PSI is safe number. Not sure that 10 psi will hit the number your looking for.
I'm sure there are plenty of members who would love to trade that motor for a smaller motor ready for boost.
Quick Reply: 454 LSX forced induction
