FI dual in tank fuel pump limitations...
I tried posting this in the fueling section, but never really got any answers (or those that I did conflicted with each other).
I'm looking to make 1,000(ish) RWHP in my turbo LT1 Camaro.
The setup;
Fully forged 383 LT1
84mm S400 turbo
115# injectors
93 octane, plus meth injection and a FMIC
I currently have dual in tank Walbro 255lph pumps (HOBBS switch and relay for pump #2).
Lonnie's says this is good for 1,000 RWHP, but I am more skeptical and think this may be more at the limit and want some extra room.
I was thinking more along the lines of dual 340lph pumps running them the same as my 255lph pumps.
Has anyone ran dual 340lph pumps in their f-body?
Anyone know the limit RWHP wise on dual 255lph and/or 340 lph pumps? It would seem to me this would depend on the fuel pressure being used, and I know mine will be a little less standard here being in an LT1.
The setup;
84mm S400 turbo
115# injectors
Restricted User
255s will make 1000 if there aren't any line restrictions and you keep your base pressure low. 340s should be able to do it under normal circumstances, even with an average 58 psi base pressure.
I ran lonnies dual 255's. -8 feed -6 return. 40 psi base pressure, 24 psi boost. Pump power is off alternator for more voltage. Straight 93 oct. Made 1009 thru th400 and 12 bolt
Keep total fuel pressure down they will make power. See the flow charts, they drop off fast with more pressure over 65 psi
I just have no idea what fuel pressure I'll be at with the tuning. I can say normal pressure out of boost should certainly be in the low 40's, but in boost, I have no idea.
I think I probably will be between 20-24#'s of boost at max on the high end. I am just concerned with running out of fuel and don't like being on the edge of "should be fine".
Restricted User
