Borg Warner help: Opinions on two different AR housings.
I was advised by two different people (very very reputable) to run the BW billet 84mm, 96 wheel that comes with it, race cover, and the 1.58 AR housing, for my 408" motor.
My question is, all I can find on here mostly is guys running the 1.32 AR housing.. But I know the white Foxbody (Can't remember the name) is running his 7 second street car on this turbo.
I 100% take their knowledge to heart and will follow their guidance, but I'm just curious why I haven't seen a ton of 1.58 AR setups on here (or maybe i've just overlooked them).
I use a Borg Warner 88 mm turbo with a 1.45 AR housing on my 408 and it seems to work very well. I have never ran a smaller AR on this engine to compare to but the engine pulls hard up to 6800 rpm and does not have any evidence of "choking" down. I have ported LS3 heads, Tick Cam, 9.5:1 compression, Victor Jr, etc.
The main reason I went with the 1.45 is a got a great deal on the turbo but I would use that again.
TH400, full suspension, etc.. Trying to go low 5's at 3300lbs.
My camshaft was spec'd by the same guy who spec'd the 1.58 housing, then another spec was made for me by a different guy and he said the same thing.
I just wanted to know if anyone knew anything about it. How well it spooled up driving around.. etc.
The 1.32 is the standard housing and I'd say most of the builds on here are 5.3 or 6.0's hovering between 800-1000 horsepower at the flywheel. If you have more cubes or want more power that's probably the reason for the bigger housing.
Well, My knowledge is limited, as this is my first turbo build. Was just curious as to what people's opinions on the big housing was. Mine is similar to a buddy of mine's car build, and his made 840 on pump gas, and about 1100 on race gas. Slightly smaller turbo than i'm going with though..
Look up toyota tacoma on here it is close to ur setup i think its on a 1.32 ar. Mi,e will be a 1.32 ar also. 408 mast heads 9.5 cr and btr stage 4 cam. If u want 1.58 call forced induction or huron they can help u
OP, shoot me an email if I can help, we are a forced inductions dealer!
Casey@huronspeed.com
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
TWITTER @HURONSPEED
thanks for the recommendation!
-Casey
-Casey
-Casey
-Casey
Ahh I see what you're saying. So using that huge housing is just maximizing the potential of the 96 wheel..
I am curious myself to see a guideline where the 1.58 would take over as being more efficient. Like a cubic inch limit, rpm or even boost psi? I know every combo is different, but a general idea. I was surprised not more people especially with the 400+ ci builds are not going with the 1.58.
LS1Tech Sponsor
The limit of these turbos will be the 96mm turbine wheel first as mentioned. The 1.58 housing will allow you to push it a little farther if you are near or at the limit of the turbine wheel. It will bump the power band up farther in the rpm range which can help a little if you are seeing the limit of the wheel falling off slightly early. Larger housing is somewhat of a band aid fix to too small of a turbine wheel but it certainly can help! More cubes coupled with high rpm would benefit from the larger housing. On a 408 you are at the teetering point of 1.32 or 1.58 depending on the rest of the setup. All it will really do is allow more exhaust in the housing moving your power band up in the rpm range which can help if your power is falling off earlier with the 1.32
__________________
Featuring 6 different turbo kits for your F-body!
i have the new billet S484 in a 1.32 96mm turbine on my 408 and it spools pretty quick. i thought about getting the new 1.58 but john bewley told me the turbine wheel itself was the restriction and when jose gets the new turbines in i should be first in line.
