Looking for 8-12psi safely stock ls2 shorblock
Old 03-22-2015, 11:37 PM
ViceCityPerformance's Avatar
Default Looking for 8-12psi safely stock ls2 shorblock
Ls2 gto. 115k miles stock ls2. Got the tvs2300 finally...
As the title states I want to try to reach 12psi as safely as possible. I am gonna run an ls9 cam and port the stock 243s. Freshen up the valvetrain with comp pushrods, lifters, springs, oil pump, timing chain.
I want to bring down the compression to be able to cope with the boost I want.
-How thick can I go with gaskets and how much will it drop my static compression?
-Can I run the stock gap sparkplugs? If not, are zr1 plugs good substitutes?
-What methanol kit can you recommend?
Old 03-23-2015, 12:00 AM
DHR Darren's Avatar
Close the plug gap to .16-18. Stock compression is fine. Read your plugs & adjust your fuel/timing by what they want.
Old 03-23-2015, 03:09 PM
mkvamso's Avatar
I ran 12 psi and nitrous with my maggie on a stock ls2
Used br7ef plugs gapped pretty tight. Get a good tune and it will live a long time. Mine had 19 degrees of timing air fuel in the low 11s at wot.
Quick Reply: Looking for 8-12psi safely stock ls2 shorblock
