Truck manifold bolts?
OEM bolts torqued to spec are more than adequate IMO. Broken bolts are usually due to over torquing on installation. I've never broken one or had any trouble. I have had to remove many broken studs. Easiest method by far is to place a nut over the stud and use a mig welder to weld the stud to the nut.
I had two that were already broken off and I broke two when trying to remove them, one even turned a couple of times then snapped, they were all pretty tight all the way out. I wouldn't mind finding some ARP bolts or something. Good trick when the stud is broke off flush or slightly recessed into the hole is keep tack welding until you get a little nipple sticking out that you can get a pair of vice grips on, I think the heat from welding helps too, came right out, stole that trick from denmah. Does everyone use the mls exhaust manifold gaskets or just high temp rtv?
Stock bolts and stock used gaskets.
Works perfect.
A little antisieze on the bolts.
Not sure why sometimes you get busted bolts on a JY engine? Either someone busted them off, or the truck just got run so hard expansion and contraction caused a failure? Usually seems to be the end bolts.
I got two out the other day by drilling for an easy out then heating the bolt with acytaline torch. Came right out.
Works perfect.
I just bought some from Napa, Dorman makes a kit of all 12 bolts. It comes with all the bolts for for like $9 for all of them and they are zinc coated with built in washer. Summit also has the kit for like $7
http://www.summitracing.com/parts/rn...IHAaAuIj8P8HAQ
The bolts dont need to be fancy or strong. If OEM bolts are breaking they are either over tightened, or simply just seized and should have been installed with some anti-seize compound.
