need some help with setting up fuel system
Ok so far ive got the following parts-
2 intank walbro 450/465s for e85
Holley 160 lb injectors
Holley -8 fuel rails
20' -10 fuel line
What fuel pressure regulator to go with?
Also not quite sure on the fuel line layout. -10 feed y'd to -8 at the rails and -8 return? Looking to support 1000rw on e85. Any insight is appreciated.
20' -10 fuel line
I need a gauge for that
Yea, they will get him about 1100rwhp or so.
Do a 50psi base, that way you have enough pump up to 20lb of boost.
You could Y right before the rails and the feed the back of both, or go in the back of one, crossover, then out to the regulator. Either way will work.
I like the aeromotive regulators.
You'll have the same setup as me (-10 line from fuel pump, Holley -8 rails). Don't feed one rail and have a crossover to the second. For that much power, split before the rails. I'll be using -10 from the pumps, Y-split to -8 before the rails, and -8 return. That should work well for you, too.
