10:5 compression on E85. How can I get more boost?
My car now is setup now to get 14#s off a 2 bar map. I have the 24x conversion on a LT1. What cold I do to surpass the 14# limiter besides getting a 3 bar map? Are their certain steps that need to be taken to reach a max of 20#s? Im just curious right now. Fuel system should support it and gate pressure is set at 8#s.
Or if this was your setup, how far would you push it? Trying to go as fast as possible. 80% track car 20% street car if that matters
I'm at just a little less compression than you with e85 and twin gt35s
Timing is pretty low, I've ran it up to 19 psi without any issues
Using 84lb injectors at 75psi base pressure
Bigger map is a must, you can try and scale it but the resolution will go to **** and it'll basically be guess work
What MAP are you using?
