Oil inlet on turbo leaking
Old 04-29-2015, 04:58 PM
bstuby's Avatar
Default Oil inlet on turbo leaking
I've got a Turbonetics 7875 bb turbo that is leaking oil from supplied fitting from turbonetics, 1/8"npt. I have a -4 feed line going into with a -10 return. It's leaking at idle and cruising around. I've tried tightening the fitting, but it's damn tight as it is. Any suggestions?
Old 04-30-2015, 08:10 AM
bstuby's Avatar
No one has any input on this?
Old 04-30-2015, 08:30 AM
Man-Crush Warning
Shownomercy's Avatar
Where is leaking, from the NPT case to fitting, or fitting to 4an feed line?
Old 04-30-2015, 09:06 AM
2005vetteTT's Avatar
did you use teflon tape when you installed the fitting into the turbo?
Old 04-30-2015, 10:36 AM
bstuby's Avatar
It's leaking on the case to fitting. No tape was used since it was already installed from Turbonetics. I used tape on the -4 fitting going into the fitting.
Old 04-30-2015, 10:50 AM
bstuby's Avatar
Should I take the fitting off and put Teflon tape on it? Bastard is in there tight.
Old 04-30-2015, 11:22 AM
Man-Crush Warning
Yes, pull it and add tape/paste.
The 4an should be a face seal vs the NPT and I would use paste sparingly.
Old 04-30-2015, 01:58 PM
bstuby's Avatar
Ill pull it and tape it. If that don't work I will buy a flange type. Thanks guys
Old 04-30-2015, 02:32 PM
jrpimp00's Avatar
It also has the filter built into it correct? tape should fix it
Old 04-30-2015, 09:35 PM
bstuby's Avatar
Yes sir. Has a screen in it. Got some tape on it and all is good right now at idle. Going to take it for a drive tomorrow and see how it does.
Quick Reply: Oil inlet on turbo leaking
