Oil pan return drain fitting help!!!
Hi,assembling my 6.0 LQ4 for install and I need to find the right fitting to install for turbo oil return in pan. My stock pan has an oil level sensor,I was hoping to use that existing hole for fitting and I know I saw an exact fitting one somewhere but can't find again for ****. Please help!!!! Have adapter plate for supply next to where oil filter goes already to feed twins. Also I've been seeing "restricters" here and there. Will I need to put one on return side to slow down oil for lube and cooling purposes?? Thanks
DO NOT RESTRICT DRAIN. If you use a restrictor (which some turbos dont need, talk to the guy your buying it from) they go on the feed side. You want the drain to be a big line with a straight shot
From the reading i've done you can't install a return where the stock oil level sensor is because you need the return line to be above the oil level or it will back up into the turbo. You want to drain as much HOT oil out of the turbo as possible to allow the fresh oil from the feed to lube it. You need to weld a bung or tap a hole above the oil level.
