ok, here we go.
#41
I’m talking WHP since that was the OP’s goal in the first post. I’m not saying it can’t be done… but it’s not a reality for most. Esp. someone looking at small T4 80mm Chinese turbos with baby exh wheels on gen3 engines.
Stock48’s new setup just put down 970 uncorrected at 25lbs. The new engine also has more, cubes, cam, and can handle more RPM (pretty sure it has flat top pistons too, but don’t quote me on that) The new engine is also running a totally different turbo than the SBE engine did. Jarrett even claims the difference between the two turbos was 100-150hp+.
While I understand the dyno was done at elevation, you can’t apply standard dyno corrections to a turbo car. Yes, the new setup would easily make 1000whp+ uncorrected at sea level with more boost. I doubt the original SBE setup would have. His new trap speeds prove the current setup is making A LOT more power than the SBE setup with smaller turbo did.
I’d also like to mention no one is anywhere near Jarrett as far as weight and trap speed with similar equipment. He is the LS unicorn.
#42
Restricted User
#43
No it didn't. It made 970 uncorrected and 1195 corrected. Like I said you can't use corrected numbers on turbo cars.
http://www.yellowbullet.com/forum/sh...590407&page=43
#44
Restricted User
I wasnt following the YB page. Just seen the dyno sheet and it didnt show any correction factor on it. He mentioned it making that at 6500 or whatever feet and I thought maybe they were uncorrected numbers.
Good to know.
Good to know.
#45
I’m not claiming the Uncorrected #’s are “real world” WHP either. Weight vs trap is closer to accurate and the hardest to fake IMO. Either way, it puts things into perspective when claimed (dyno’d) “1000+” hp cars in lighter chassis trap 10-20 less mph than Jarret’s combo.
In the OP’s case I really think twins are the way to go. A single capable of similar power is much more expensive. He has all the space in the world in the back of that truck and it puts the weight where he needs it.
#46
I always wanted twins. Then I got married. But hey, theres still hope.
Anyhow, I am good going with a twin setup in the bed. But would much rather choose a turbo without internal wastegates. I don't know about them really, so I like to stay in my comfort zone so to speak. Which turbos would be suggested now with external wastegates?
I am also most likely going with the A2W system. I have a plan laid out for the bed. Its going to be a bad *** setup. I am so ready to order some parts.
I just cant tell my wife.
#48
It’s hard to beat the gt45 for price/reliability. ($200 shipped) After seeing what a tiny shot of nitrous for 1000rpm or so can do for spool-up, I’d go with them as well.
If you don’t want to mess with nitrous, the gt45’s will be on the laggy side with a mild 6.0. (Esp. remote mounted) The ON3 70’s would spool up better ($325 shipped) with the .68AR housings.
http://www.ebay.com/itm/On-3-Performance-70mm-Turbocharger-t4-Camaro-Firebird-/141727056011?hash=item20ff97408b&vxp=mtr
#49
I can handle a being a little laggy if it isn't too bad. I plan to install a converter when I do this even with the engine staying stock. That should help it quite a bit. Heck this truck needs one now. LOL. Its a 60ft turd. On the final build, its going to get a bit more serious under the hood. I don't plan to increase cubic inches though. But you never know.
#55
Anyone have an idea if this cam is good for my build?
247/247 .615/.608 112 lsa 300 ultradyne
Also going to pick up a new Turbosmart Race Port BOV tomorrow from a member here. Got an awesome deal on it. Rod bolts on the way as well.
Looks like I am going to go ahead a build the engine now so I don't have to do it later.
#56
Parts are building.
Bought a TU2 cam with BTR .660 ti spring kit. ARP Rod bolts. BTR pushrods.
As soon as I get all the engine parts I will pull it, tear it down and have the block cleaned and cam bearings installed. Balance the rotating assy and put it back together.
Then I will be able to just install the turbo setup once I build up those parts and the engine will be ready to go.
Still trying to decide what to do about the trany. Either keep the 80e, build it and add a converter since I plan to drive it on the street. Or go Th400 or PG.
#57
Yea, I know. Wow a slow build. LOL Haven't started the build just yet as I am still getting all the parts together. But I am very close. I've been very busy with my businesses so not a lot of time to mess with the truck. Spending time on my Lemons race car since we have a race in a couple weeks.
So far I have everything for the engine build except trunion upgrade, bearings and rings. I want the machine shop to clean the block up, check it out and balance the rotating assembly to be safe on what size I need for everything. I also need a fuel pump, but haven't deiced which one to get yet.
On the turbo stuff I now have the Turbosmart Race port BOV, a BW S482 turbo, eBoost2 controller. I need the wastegate but should have one in the next couple weeks. Waiting to the last minute basically for the A2W IC, Ice tank, pump and hot & cold piping. Not sure if this is still going to be a bed mount or not.
Picking up a built Powerglide trany with a Hughes 3500 turbo converter in a couple weeks.
One thing I am trying to figure what I want to do is the engine management system. This is something I am truly clueless on. Do I keep the stock ECM and use the HP Tuners or go aftermarket like Megasquirt or someone else. I've been reading a lot of bad things about the Megasquirt so I am getting leery on that one.
#59
Its all really beyond what I personally know about the electronics and tuning and such. While searching for info on all kinds of things, stuff pops up and I check it out. Such as https://www.facebook.com/MegaSquirtSux/
Again, I don't know a lot about these, so I am having to rely on others info.
There is other posts on other forums as well. Now this doesn't mean that I wouldn't use them as I am still leaning that way. I was just wanting opinions from guys running this stuff to see which one is the easiest to work with and maybe one works better than the other. If the consensus is that a certain product is best, then that's the way I would most likely go, even Megasquirt.
#60
That guy does seem like a butt hurt idiot though.
I will say that there is only one system I have found that can do everything that ms3 can and it costs over 6 grand and they have to install it for you.
