Installing 3bar MAP in LS2 intake. Need advise.
So Im procharging my LS2. I already purchased the generic GM 3 bar map but the hole in the intake is too small, and I would need to drill the hole for the securing screw. Before I go cutting my intake up..... I wanted to do my "measure twice" by making a thread and maybe getting some more input from you guys.
All suggestions appreciated!
Restricted User
Does the LS2 intake use the same MAP sensor as the LS1 intake?
EFI Source sells a plug and play LS1 3-bar MAP that replaces the stock MAP sensor as if it were a factory replacement.
Im running a LS9 map in my ls2 intake. You will have to change the pigtail tho.
BTW, whats the difference between the different 3 bar map sensors, how do they affect timing using one part # compared to another?
