Turbo lq4 blowing oil under boost
I'm having a hard time trying to figure out how to solve my constant oil leak problems. My specs are in my signature. The problem is that after making a pull under boost I develop oil leak from what seems to be the rear of the motor my starter,oil pan and bellhousing will be dripping oil.I have a -4 feed from above the oil filter block and a -10 drain going to the front timing cover. I'm using the stock ls1 pcv system untouched. Wondering if I should try a vented oil cap..or a catch can since I'm noticing oil residue at the exhaust pipes and back bumper. Is it possible I may have started to push out a rear oil seal on the motor from boost? It never had an oil leak before the turbo setup. I hate having people stare at the car as it warms up and begins to burn off oil and smoke. The smell gets to you after awhile. Any suggestions?
Stock LS1 PCV system untouched...and therein lies the problem.
The engine will either have no breathing at all under boost, or you're pumping boost into the crankcase
pressure in the crankcase. Invest in a catch can. You may still need to check the rear seal as well, If youve done this enough times. Its possible it will still leak after the catch can install. May want to put in a new rear seal.
So I had the car running with the vented oil cap and it does indeed allow the oil vapor mist the engine compartment.Ive wrapped a rag around temporary to reduce it.The car is going on the dyno in the morning and tune so hopefully things go well. Now i need to shop what is a good catch can for the money that isnt just a pretty anodized can under the hood.
Just installing a catch can isn't going to help with pressurizing the crank case. You have to be able to relieve the crank case pressure you are producing. A catch can is to catch the oil FROM the blow by, that is getting back into the intake track. It's not going to relieve any more pressure than with out the catch cans. In order to relieve crank case pressure, you have to have bigger vents. Which is why some suggested a vented oil cap.
I personally have -10 AN fittings coming off of both valve covers, and I run those to a catch can that is vented to atmosphere, instead of back into the intake.
Well, that's good and I've heard it's a quality product. But you are still working with the same OEM size outlets off of your valve cover and your valley cover. Those are where the restrictions are happening. Which is why adding a vented oil cap helps. You are adding one more place for pressure to leave.
Thanks for all the input.Im just playing the waiting game for my catch can. MM has a 2 week waiting list before it will be ready.For now im just venting everything to atmosphere which is working great..except for it looking like steam coming out of the hood and ppl freakout sometimes lol.
