Oil pressure dropping when coolant temp reaches 215-225
Hey guys, I have a new engine from Thompson motorsports with about 800 miles on it. Huron speed turbo kit. Makes 879rwhp. Ive noticed on 90+ degree day the engine temps run up to 215-225 after some hard pulls or cruising around town. Im not sure what the oil temp is but the gauge at idle goes down to 25-30psi when its this hot. Driving it comes back up to 40 but at idle I drops down there lower than I would like to see. I have a melling high pressure pump, and running Valvoline vr1 20w-50 oil. Is this normal??
Sounds like the oil is getting hot and thinning out. Bearing clearances will also play a factor into your oil pressure.
Does oil pressure rise when you increase throttle?
I have an oil temp gauge and my oil temps will rise after pulls and it takes a little bit to get them back down. If my coolant temp is 190-200 my oil temps are 210-220ish and will climb with pulls. I have an oil cooler out front to help bring the temps down.
I would say this sounds about normal. Is Thompson Motorsports not available to give you more information? I would guess they'd be the best people to ask as they assembled the motor, no?
Yea, that's completely normal in my eyes. Oil gets warmed up, thins out a little and pressure drops at low rpm. I have never built an engine, including 1000hp NA engines that didn't do that. Its what oil does. 25 at Idle may not be what it should be on a new engine depending on how they built it, but its not hurting anything.
Run the oil restrictor, You have a huge oil demand feeding the turbos with no restriction. When the oil get hot and thin it is going to loose oil pressure if there is not something to hold it back. This is not un common without restrictors
Just for reference, today I drove my car to work in stop in go traffic with ECTs at 190ish, oil temp sitting right at 205ish. I run 5/40 rotella synthetic, bearings are setup pretty loose at .003.
Idle oil pressure is 40lbs.
I do have restrictors in my turbos (they come with them from turbonetics).
