New SBE record 8.19@167
Old 09-02-2015, 12:26 PM
  #61
TRIXLSXSUPRA's Avatar
Originally Posted by silver_82
Its a street car that gets driven long distances so i built this. Its a bit crazy but works really well for a high hp streetcar on E or meth. Totally overkill and complex for a track only ride.
16 injectors, primarys are 36lb/hr secondarys are staged and are 160lb/hr
The primarys are fed from a walbro 255 and can support up to 10psi at 4500rpm
The secondarys are fed from a clutched belt drive pump that kicks on automatically with demand or when the boost control input is on . This way i have a fuel system that will support all the power i could ever want but not pumping fuel needlessly for hours on end.
Nice i'm intrigued at the clutched belt pump can you share anymore info/pic of it and what pump are you using?
I know you drag week guys tend to have very complex fuel systems for all the street miles you have to put on the car......
Kudos to you obviously very well thought out and executed set-up in your turck best of luck on the upcoming drag week event i know i'll be streaming it and will look for you
Old 09-02-2015, 12:31 PM
  #62
oscs's Avatar
They are 4". Building an easily removable filter for it now. Been running like that for 2 years and ive been lucky nothing big has gotten pulled into the turbos. It was one of those last minute get ya by things that seem to get put off forever.
Looks great. Im in the process of doing the same thing as we speak.
Old 09-02-2015, 02:44 PM
  #63
silver_82's Avatar
You and i think exactly the same because thats exactly what im doing. A c6 zr1 air filter is going to slide into an enclosure in that secion of the air dam.
Its easily removeable by loosening the perimeter screws and pulling it out, leaving a giant air duct for racing.
Old 09-02-2015, 02:52 PM
  #64
silver_82's Avatar
Here is a vid i made over the winter that shows it working and gives a general overview. It uses alot of 1 off parts that 2 very good machinist friends made for me.
https://youtu.be/Y6PV1yXdG9A
Old 09-02-2015, 03:36 PM
  #65
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
Chris u using an iron block?
Old 09-02-2015, 03:49 PM
  #66
silver_82's Avatar
Yeah its iron
2005 lm7
Old 09-02-2015, 04:02 PM
  #67
Thanks for the link that was very informative and def a great setup that WORKS!
Always nice to have guys like that at your disposal.
Hope you don't mind but i may have more ?'s for you in the future so i'll pm you then
Old 09-02-2015, 10:56 PM
  #68
831jd's Avatar
What valve springs and lifters?
Old 09-03-2015, 07:28 AM
  #69
silver_82's Avatar
Regular patriot golds and the factory gm full bodied lifter that they started using in all models around 2005
Old 09-03-2015, 05:21 PM
  #70
7 Second Club
ls3fox's Avatar
The fuel pump setup is awesome good luck at drag week
Old 09-03-2015, 08:14 PM
  #71
dudeman's Avatar
good job man!!!
Old 09-04-2015, 10:36 AM
  #72
T.Fiddler's Avatar
Very nice!
what kind of timing numbers ?
Old 09-04-2015, 11:21 AM
  #73
silver_82's Avatar
Thanks to everyone for the compliments.
Old 09-04-2015, 01:03 PM
  #74
oscs's Avatar
Default New SBE record 8.19@167
Originally Posted by T.Fiddler
Very nice!
X2 I wanted to see the whole table
Old 09-04-2015, 01:31 PM
  #75
Forcefed86's Avatar
LS1Tech 10 Year
Sometimes it's enough just to know the white unicorn exists...
Old 09-04-2015, 01:42 PM
  #76
T.Fiddler's Avatar
Lol
I just want the lowest number
Old 09-05-2015, 02:20 PM
  #77
Forcefed86's Avatar
LS1Tech 10 Year
I know it's been said before, but which 366's are you running again? Is it the .91 with the 73mm exh. wheel?
Old 09-05-2015, 02:32 PM
  #78
4Jenna's Avatar
Grats!
-CE
Old 09-05-2015, 09:45 PM
  #79
silver_82's Avatar
Out of the box cast wheel. .88 housings 73mm exhaust wheel
Old 09-06-2015, 02:04 AM
  #80
oscs's Avatar
I suppose you're right. It probably wouldn't do me any good to know
Quick Reply: New SBE record 8.19@167
