2000 Z28 6.0 LY6 7875 Turbo Build
Old 01-04-2016, 08:09 PM
  #81
MY_2K_Z's Avatar
Here's a better pic now that the sun went down
Old 01-13-2016, 08:53 PM
  #82
MY_2K_Z's Avatar
Going to do the fuel system next weekend and try to pick up a ford 8.8 to swap in while the file tank is still out.
Old 01-20-2016, 11:49 PM
  #83
MY_2K_Z's Avatar
Anyone in the Houston area have a decent 4l80e they want to let go at reasonable price. People around here think they are gold and want 700-1000 for a 250,000mile pos.
Old 01-30-2016, 10:43 PM
  #84
MY_2K_Z's Avatar
Got the dual 450s installed today. It was much easier than I had anticipated, it's probably the easiest thing I've done this far on the car. Ill post some pics soon.
Old 02-01-2016, 08:06 PM
  #85
MY_2K_Z's Avatar
All I'm lacking is the y fitting and an 8an to npt adapter.
Size:  194.0 KBName:  D401CBA1-85EB-4328-A370-43E9746C0FB8_zpskpwbz28r.jpg
Size:  155.3 KBName:  31012930-0ECF-4579-9781-F788675D066C_zps9uivaneo.jpg
Size:  168.5 KBName:  F2317381-4832-4D80-95E7-89D3CC0E318B_zps03auxq5q.jpg
Old 02-08-2016, 10:06 AM
  #86
80/TA/LT1's Avatar
Really liking your build man, I'm getting some ideas for my own and have a question. Are you planning on mounting the turbo somehow or just leaving it hang off the manifolds? I've got a gt 45 and it's heavy as all hell, makes me nervous about not mounting it , that's why I ask... Thx looking good
Old 02-13-2016, 07:47 PM
  #87
MY_2K_Z's Avatar
So I'm looking for a fuel filter now and need to know what micron I should go with 10-50-100 I have no idea. 8an inline filter is what I need.
Old 02-13-2016, 08:37 PM
  #88
98Camarod's Avatar
Post pump filter should be fine. 10-30 micron
Old 02-25-2016, 08:04 PM
  #89
MY_2K_Z's Avatar
I do plan to support the turbo not just let it hang
Old 02-27-2016, 07:54 PM
  #90
MY_2K_Z's Avatar
Finally found a good deal on a 4l80e locally $400 delivered. It will be getting dropped off tomorrow so I'll try to get the engine and trans back in this week.
Old 03-26-2016, 10:22 PM
  #91
MY_2K_Z's Avatar
Tested the fuel system today. Seems to be working as it should, set the regulator to 60psi and also tested and rises as it should with boost. The walbro 450s are surprisingly quite as well.
Size:  150.4 KBName:  B456E2B7-AF0C-4753-BB90-29EECD9FF526_zpssmdk1ewy.jpg
Old 03-27-2016, 12:01 AM
  #92
MY_2K_Z's Avatar
So all I'm missing now is a harness, ecu, trans crossmember, injectors, and a shortblock. Hopefully I'll have time to do that stuff in the next few months, work has been very busy and I just havnt wanted to work on the car after working so much plus I have another fbody to paint for a friend so that will take up a lot of my free time.
Old 03-27-2016, 12:07 AM
  #93
DavidBoren's Avatar
Awesome progress, sir. The cerakote and wrap turned out very well. Keep it up man, this is still one of my favorite builds.
Old 03-31-2016, 11:27 PM
  #94
MY_2K_Z's Avatar
Thanks man I'm taking a while but I think it will be worth it in the end.
This is how it sits now. I'm goin to build a new radiator support I didn't like how this one position the radiator so I cut it up to force me to make a new one
Old 05-22-2016, 04:10 PM
  #95
MY_2K_Z's Avatar
Havnt done much lately. Finished the fuel pump relay wiring and battery relocation stuff, also finished the insulation for the most part this afternoon.
Old 06-12-2016, 05:07 PM
  #96
MY_2K_Z's Avatar
Ok guys I got a harness but I need help finding a part number for the plug that has been cut off. It'a the plug that goes through the firewall on the passenger side on a 99-02 fbody.Name:  82A88B96-7A6F-4054-ABC8-C511D9EF5E19_zpshlrcmkpn.jpg
Old 06-12-2016, 05:19 PM
  #97
93hatch's Avatar
you need a flex section on that crossover, unless its covered up
Old 06-12-2016, 05:25 PM
  #98
MY_2K_Z's Avatar
Maybe. I've seen hundreds of build with and hundreds without. Sometimes they have issues without the flex section but I've also see many that had no issues. If it does become an issue I'll add one.
Old 06-12-2016, 05:40 PM
  #99
MY_2K_Z's Avatar
Figured out the harness it's the c220 and c230 plug I need
Old 06-13-2016, 03:11 PM
  #100
98Camarod's Avatar
Worst case, just crimp on the male/female disconnect insulated connectors. They are going to be on the interior.
Quick Reply: 2000 Z28 6.0 LY6 7875 Turbo Build
