new dyno numbers.....
i have 370 iron block,317 ported heads,stage one cam, holley midram. s484. 400trans. 9 in rearend. on 16 lbs car made 800 wheel with a volt issue. i think that tose are some pretty good numbers, what do you guys that are more into the boosted seen think. plan on turning it up too 25-30 when we get the issue fixed
Restricted User
You're right, but seeing what he made power wise on 16 lbs, and with his given cubic inches and turbo size, one could possibly draw the conclusion that above 25 lbs his cylinder pressures will be quickly approaching the point where he may lift the heads.
