those of with a s484
ill start off saying i know this is a bit of a vague question but just curious when you all are starting to see boost and then when are you making full boost?
if you can try and describe a little bit about your build. how much boost cubes turbo specs compression gearing etc
I don't have an S-484, but I do have an L92 w/ an S-480. It's a billet wheel V3 with a 96mm 1.10 a/r. I have a 2" hot side and a full 4" exhaust with muffler. It has a JFR cam in it and a 4L80 trans with a tight PTC converter. I'm only able to footbrake to 3000 rpm on the two step, but as soon as I let go of the brakes boost climbs to 11 lbs (wastegate spring) fairly quick. I still have quite a bit of tuning left to do, so I hope to improve this.
