"Low down & dirty" 5.3-78/75-TH400 Skylark 11.25@122
#221
Scored a shifter off craigs, ***** mint
This is my old Micro out of the car. Who loves a clean wiring job?
Ready to go in
Brake cleaned all the oil off the E-bay.. ***** good
Sideways mofuckkaaa!
And it's in
Old hotside is going awaayy
76/68 on top 78/75 on bottom both from VS racing
Making the manifolds face forward and down like a boss
#238
Do you monitor KR with Microsquirt? Can it do that?
I'm not an expert but I drop to 19 deg timing the second I get into any boost on 91 octane - even 2 psi. It looks like you might be in the low 20s from your table when it first starts boosting?
I logged KR for a ton of hours and found this was the area I was most likely to knock...At higher boost the computer is averaging areas of the table which all have low timing, but the transition into boost it can average fairly high numbers - that is if MS works anything like the stock ECU.
#239
@forced yup! plus it's pretty budget friendly haha so far so good
@callys I am now running the Gold box. KR? knock sensors? I'm sorry idk if that's what you meant there. I don't have them plugged in. I will be installing a meth kit here shortly that will turn on around 14psi. I also had little to no ring gap on my old motor (never checked it just ran the motor) so hope to see better results. Thank you for your input and I will keep it in mind !
