Street tires that hook
im gonna try proxes tq's I hear good things about them. I've mickey Thompson dr's and yes they wear fast but they also hook like none other on the street. right now I'm looking for the best hooking street tire woth atleast some sort of sidewall that's actually stable around turns. I feel like your probably wanting something similar? if anyone has any other real experience please chime in I'm interested as well
I don't know what happened to my MT 255/60/15 DR's but I think I got less than 1k miles. BUT - here in the northeast we had a lot of snow events this year and the roads were constantly covered with snow or the brine solution, so the tires spun a lot which I think ground them down. They did hook nice when they were working.
Define street tyres....what size range you need...and of course even a wastegate is a boost controller.
As Skinnies proves, with the right combo and boost control he can get even plain old M&S radials to hook very very well.
Likewise Z can get his RX7 to hook very well on very normal tyres.
So obviously tyres will make the job much much easier, but control over the power delivery is far more important.....so in that respect there are boost controllers...and there are boost controllers.
Do you have a good one, or bad one ?
For a street tire I have found the 555r to be amazing. They last forever and are cheap
They are hard enough they will not ball or feather so you never have lost traction vs say the mickey which are just too soft for a true street tire
There is a learning curve to the tire, don't shock them and you can pour it on big time
On the street on high lower I went through a set of mickeys in 2 weeks... And even being very cautious not to blow them off. The power shreds them up on a rough surface like asphalt.
I'm using the boost control in the Holley. But even with just gate pressure (7psi) my 225/55/16 BFG that I'm running for now cant hold **** off the line. I may look into the 555's, Nitto only has 245/50-16 avail - think this is a good choice?
I'm using boost vs speed, and really don't ramp any additional boost in until after say 30-40 mph. I did get 16psi to hold last night after about 70mph so there's some promise I guess.
Cant believe how cheap these are:
http://www.jegs.com/i/Nitto/726/40133/10002/-1
I'd like a little fatter but that is all that is offered in 16" I believe.
For me on high power the mickeys where good for 1 maybe 2 hits where traction is great, then they are balled up and traction goes down very fast. Need a burnout to clean the surface again
Probably alot of what you are seeing
The nitto will not do this. They will look like this regardless of what you do to them. I have full traction potential all the time. Can make 10 hits in a row and all is good
Def over 1000 honest HP in this video when all in. And you can see the surface. It is over 1g acceleration by 80mph. 26" 275 nitto
I could do that over and over like a bracket car.... But if I didn't control the TQ delivery and just let boost wack in like a light switch I'd smoke them on a 1/3 that power
