how are you guys putting a -8 bung in turbo inlet for catch can?
Im routing my MM catch can. Im going to run the -8 to a bung on the turbo inlet like the instructions show. I have a s480 with race cover. Its 5.5 inches. Ive thought about getting a thing piece of aluminum to bolt in between the filter and turbo. If anyone has pics on how they did theirs. That would be awsome. Thanks!
How would that make a diference if speed density? The turbo inet is my only filtered in air source, right? That confused me. Lol Im going from the oil fill to the can. Can to the turbo inlet. Thats what the instructions show and how mighty mouse said to hook it up. Ive seen guys thread it into the plastic end of the air filter. I dont like that. Any suggestions on where or what to use for the spacer? Have to be able to clamp it to the turbo and clamp the filter on the other end.
i'm not familiar with the MM set up. I'll share with you my preferred set up.
it's similar to the stock set up where "clean" air is drawn in from the inlet tract ahead of the throttle body but after the MAF. that way air that enters the PCV system is metered.
it goes into one valve cover, through the crank case, carrying any unwanted blowby gasses out through the "dirty side" valve cover. some LS's use a restrictor here, some a check valve. from there it's drawn into the intake after the throttle body where a vacuum exists at idle and part throttle.
i prefer to put the can after the "dirty" side valve cover, to catch an oil before it goes into the intake.
i mentioned speed density, because you do not have to worry about unmetered air bypassing the maf with SD
I see what you are saying. Thank you for the info.
Im running mine as a draft can.
Just one dirty side. Clean side to turbo. They have the filter and check valve built into the can. All other air sources are blocked off except the oil fill in the valve cover.
You would have to run a check valve in between the valley cover and filter otherwise in boost. They both are the dirty side then, wouldnt they? Lol or are you running the clean side of the catch can to it?
Im trying to see how other people have done exactly that. I dont think there is enough room though to tap it and get the filter on to clamp it down. Theres not much room.
http://static.wixstatic.com/media/dd...0_0.00_jpg_srz
Look at this link. Instead of running from valley cover to compressor inlet, i ran to a separate small filter (about the size of a filter for a valve cover).
The last turbo filer I used allowed me to drill and tap a hole and I ran a hose from the valley cover to the end of the filter just like the pic.
I am running SD by the way.
I see. Those instructions are dor the pcv can. I have the draft can.
The way I was explained is during normal driving. The turbo isnt spinning fast enough to create more vacuum than the motor. So it acts like a normal breather. When you get into boost. Its spinning fast enough to shut the valve and actually pull crank case pressure while of course its being forced in by the turbo.
There is a guy here that did a youtube video. He is running e85 like me. He had a ton of water/oil in the can after a short while.
The physics behind it make sense. Im still looking for examples of how people have set theirs up. Id like to weld it. Might end up getting a rubber coupler and drill a hole in it. Tighten the bulk hed and epoxy. That would be a last resort.
8 Second Truck Club
If trying to create a vacuum by putting a line at the front entry of the volute...........has anyone seen any issues with the thing working good enough to suck oil vapors into the inlet of the turbo or blower? That could create some issues with detonation if it was significant enough.
I wouldnt see how its any different than when going back to the intake just like stock. If the catch can is working properly, its going to seperate the oil/air like its suppose to and not be putting it back into the motor or turbo. Its not going to get 100% im sure. Its there to help keep as much oil out as it can, from recirculating back in. Not a fix for crazy amounts of blow by. Im no expert by any means. You can pm Mighty Mouse. He is the expert and great guy to deal with.
I know there are lots of ways of hooking them up. Not trying to argue one way or another. Just looking for examples of how other people did theres when hoing to the inlet of the turbo.
The turbo is the only filtered air in source.you would get a venturi affect like a carb. Is how I understand it. It comes into play when it boost. Once you get the inlet spinning past 0 vacuum. Its pulling the crank case pressure. It has a valve built in that closes off the breather when in boost. Directing straight through the can. Thats how I understand it.
Any of you have anytype of extention in between the turbo and filter? Still looking for examples. Lol
So I routed mine probably similar to the way you are looking to do it. I did not want or seem to have the room to tap into the turbo inlet so I went into the metal end of a K&N filter. The car is being tuned at the moment so I can not comment on how it works under boost but this may be another option for you. I hope the picture shows up
