Twin turbo 93 LS Notch
Bit the bullet on an AC/DC TIG welder finally. Pretty excited to test this thing out. Went on sale for $499 recently. I Made a $450 offer and they took it!
http://www.ebay.com/itm/TIG-Stick-Sq...IAAOSw~gRVhK2B
Trans control, packaging, extra weight, more expensive parts, more expensive converter… etc. OD trans just aren’t worth it IMO. A typical turbo V8 of any kind can pull a tall enough gear/tire that it’s not needed. OD is a luxury I can afford to give up. With a 2.73 gear and 27” tire I’ll be able to cruise about 65 at 2200 rpm. That’s more than good enough for my needs.
The following users liked this post:
Taw_Thruat (11-11-2020)
Ok, makes sense. Didn't realize you were going to run such a tall gear. They are definitely heavier, the 80e in my hatch is almost 190 lbs. dry, with no converter. I was pretty surprised when we weighed it.
Any details on clearance on that oil pan with the AJE Kmember? Looks pretty good.
I like your style with the car but i may be a bit biased haha
Im using the AEM380 pump too. So far its working good but i haven't gone WOT with it yet. Just started the tuning
Now that you mention it I’m a little lost on Rear brakes? There are so many options it makes my head spin and this is my first foxbody.
I have an 8.8 with drum brakes and 4 lug axles. I’d like Disc’s in back strictly for the purpose of holding the axles in in the event of a failure. Looking to get by as cheaply as possible, I don’t care much about the stopping power of the rear brakes or going to a 5 lug pattern. What is the easiest route here?
Should I upgrade axles? This car will have a small tire and power will be ramped in progressively with traction/boost control. So I’m not 100% sure I need axles. Can I slide a 28 spline aftermarket axle into the OEM LSD without difficulty? Is this even worth the trouble? Or is something like a mini spool (of full spool I don’t care) with a 31 spline axle preferred?
Again just looking for the cheapest route to get the car up and going without the fear of an axle/wheel assy flying off the car.
I was looking at this bracket for $125
https://scarebird.com/index.php?rout...product_id=137
It also looks like you can get a 92-02 mustang gt brake brackets and cut them?
http://www.mypowerblock.com/group/fo...ake-conversion
…I’m lost.
…I’m lost.
…I’m lost.
…I’m lost.
Another option to hold the axles is a C Clip Eliminator. Arent too expensive and can be used with stock axles and drums.
http://www.moserengineering.com/othe...ody-fords.html
#32
Oddly enough that is going to be my next thing I upgrade on mine haha I'm running stock 8.8 with drums and 4 lug. For a quick slight upgrade you could get some 28 spline (stock spline) axles from an aftermarket company. They claim to be slightly stronger. I think you can swap brakes over from a Turbo Coupe and I believe they are 5 lug and disc! Could probably find that stuff at a junk yard.
#34
For ease of install and resale I like the discs over the C-clip eliminators. Some of the mini spools are dirt cheap on ebay (like $65?) and are available in 31 spline. Theres actually a set of 4 lug 31 spline axles on my local Craigslist for $180 (w c-clips). Is that a good deal? Should I just grab them?
#35
Used?
They have the C Clip Elims with them?
If they are new that is a really good deal. Considering the axles are 220-300 depending on brand. If no Elims are included and they are used then I would just spend the extra 40 for new axles personally.
#36
I went with a 5-lug 3.27 rear on mine, came with disc brakes already. Whole rear was ~100.00. Then installed the 31 spline cobra diff for like 280.00, and a set of moser axles. But I did weld on 9" ends for retention. Unfortunately you need a jig for that.
I just don't think the discs will hold the axle in effectively...b/c the caliper is so far from the centerline of the axle, I think an axle will be able to push the caliper/rotor out of the way. Better than nothing I guess. I think I like the eliminators better here.
#37
No the axles have the provisions for c-clips on them, not the actual eliminators. Found another 4 lug 31 spline set just like this for $144 shipped on ebay. Suppose if I’m going with 31 spline I’ll get the CCE deals and a full spool, then just keep the drums to save a little money. Still gonna cost around $500. What a pain…
I’ve never seen an axle evacuate the rear with disc brakes and I’ve seen a ton of axles break. Not a lot outward force to push them out past the disc brake bracket I’d guess.
#38
I have a 8.8 fox housing with the ends cut off and I have a complete 8.8 from an Explorer with drum brakes and 5 lug axles. When the time comes to build the rear for my car, I was going to take the internals from the Explorer rear and cut the ends off and have them welded to my foxbody 8.8 and run explorer rear drum brakes with a set of c-clip eliminators if possibly. Is my idea unheard of? I have less than $200 in both the complete Explorer 8.8 and the bare Foxbody 8.8.
Just like Forcefed86 I am trying to put my entire car together for as little as possible, but have a fun reliable car that is still clean even though I didn't sink a ton into it.
#39
…I’m lost.
…I’m lost.
#40
…I’m lost.
…I’m lost.
As far as the rear brakes I heard a lot of people saying the rear discs work off a Lincoln/Grand Marqius/Crown Vic????
Again, I never tried any of this stuff myself but it may be worth researching if you can save a buck.
