Twin turbo 93 LS Notch
#101
Appreciate the tip, I didnÂ’t know that. CanÂ’t imagine IÂ’ll have issues keeping the nose down. This will be a 100% street toy with traction control. Running factory wheels with some 245/50R16 Nitto Drag radials on a 2.73 gear. 650-700 HP crank is the goal. IÂ’d like as much weight over the rear wheels as possible and as little as possible everywhere else!
#102
LS1Tech Sponsor
What's your bottom end setup and what oil pan are you using? We may have one of our new billet versions that will bolt up to your application with modifications. If so we can replace it for you. We just need to make sure that pickup tube will bolt up to our windage tray.
#103
#104
LS1Tech Sponsor
Thanks!
#107
Got the fuel surge tank and all the fuel lines/filters ran. Test filled the surge with stock fuel pump. All is well. Turned out great.
Ordered a large china oil cooler to use as a trans cooler. This things pretty massive, with a 2" thick core! About $80 with the AN fittings to adapt it down to AN6.
#109
Not as far along as I wanted. Between the 100* temps and the RX-7 making metal I haven’t spent much time on it. Got the RX-7 going again this weekend, hopefully that’s not eating anymore of my time this year. Hope to make some serious progress in the next few months. Got our first kiddo due Dec.20… Goal is to get it running before then.
#110
#120
Few updates this weekend. Pulled the 4.8. Installed the $450 10” PTC converter and bolted the TH400 up to the Alum 5.3 and dropped it in.
Also installed a new accumulator & master cyl, bled brakes.
Cut some holes for air filters. Have some new filters with socks coming.
