Daily driven boosted 5.3
Old 05-11-2016, 02:10 PM
7 Second Club
Rich Halsey's Avatar
With the ability to turn up the boost, you won't be happy with 500 WHP for very long......
That is the truest statement ever!
Old 05-11-2016, 02:40 PM
saleh660's Avatar
Originally Posted by JoeNova
Meth injection is NEVER a bad idea. Ever. I can't even explain how many times it has saved my engine. I pinched my wastegate diaphragm changing springs and pegged my 30 lb boost gauge and didn't notice it right away. No idea how much boost I actually hit. When you're 15:1 lean and running 30 PSI with 10:1 compression showing almost ZERO knock, something saved your ***. It wasn't the junk pump gas I was running, either.
I am limited to 91 octane, my engine is 5.3 with gt45 , china head studs and 317 heads ( yes it's dog out of boost ) I've been running this setup for over a year with zero issues
I did start with 7 psi and now 13 psi and 14* ,I am thinking of increasing the boost to 18 psi maybe but I am worried. what do you think ?
Old 05-11-2016, 05:19 PM
Restricted User
JoeNova's Avatar
Running water/meth?
Old 05-11-2016, 10:10 PM
saleh660's Avatar
Running water/meth?
water injection kit fitted to the car but I haven't used it before, I am considering running 50/50 with DO10 nozzle ( 14.14GPH )
Old 05-11-2016, 10:17 PM
Restricted User
JoeNova's Avatar
You're compression is so low that even at 18 PSI with 14 degrees and water/meth, 91 octane should be fine.
Old 05-12-2016, 09:21 PM
trez28's Avatar
Thanks to all of you, I'm feeling very confident about this build.
Old 05-12-2016, 09:40 PM
MY_2K_Z's Avatar
You don't have to push it far for the street. On 10 lbs, my MT ET street radials (255/60/15) won't hook in first gear on a good day. On 15 lbs, the car goes sideways from a 50 roll. 20+ lbs and I can leave stripes on the highway.
I took the heads off a month or so ago after running 30 PSI a few times. Pistons were perfect, rods were straight, head gaskets looked new.
Posts like this are what me decide to build a turbo car. Can't wait to leave stripes down the highway
Old 05-12-2016, 09:42 PM
trez28's Avatar
Lol I have to work myself up to that
Old 05-14-2016, 04:18 PM
trez28's Avatar
Another question guys what ecu did you guys use, also plan on using a 4l80e and I know I'll have to replace the rear end.Is there anything small you guys can suggest I get that I may not think about?
Old 05-15-2016, 05:09 PM
laytoncamaroz28's Avatar
I swapped to an 02 truck pcm on my 98 Camaro. Use efilive with a custo operating system and tune it myself. I'm not much of a tuner but have a friend who gets me a nice base tune and then is very simple doing small afr/timing adjustments. And I'm also running a stock 80e and the PCM controls the shifts making it very street friendly. I drive 16 miles a day to work. Engine is a stock longblock lq9 minus JFR 221 cam and pac springs with an on3 78/75 turbo. Makes 690 on e85 and 570ish on pump gas.
Old 05-15-2016, 05:35 PM
trez28's Avatar
How much boost you running to produce those numbers?
Old 05-15-2016, 06:30 PM
  #32
8 psi on pump and 12 psi on e. I tried tune in it up higher but it don't make more power. Time for an upgrade
Old 05-15-2016, 06:33 PM
  #33
trez28's Avatar
That's awesome, lol you can't simply turn up the boss to a little?
Quick Reply: Daily driven boosted 5.3
