Procharged 396 LTX (built by ellwein)
Badass build! The LTX community will appreciate it. It's nice to see someone not hold out and go ***** to the wall with quality parts in a build.
Op, your engine bay looks super clean and well taken care of. Do you have pics of your entire car and interior?
Also, I'm not happy to hear about Ai's customer service. I plan on pulling the trigger myself and getting their Trick Flow H/C/I next month unless they convince me to go with their stock 200cc, but I doubt they will. I'll find out about their customer service myself soon enough.
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
Nice! Keep it up! Yea LS make more power but you have a hybrid. I like to tell people how bad of a motor the LT1 is and then they look under my hood and see what I'm packing and they are scratching their head and asking how much power I'm putting down again lol. I think you'll hit 700 if not pretty close given that the blower will probably be maxed out. My F1r old setup was pullied with a 4.5 with 7.65 crank with smaller cam pushing just under 15psi. Keep us posted.
Totally subscribed to this build thread. It is refreshing to see an LT1 thread in this forum. Not sure if I missed it, but what went into your decision to go 396? That would be my dream build, not to mention having Ellwein's name on it.
Nice build and parts. Don't worry, I get the same grief from a guy down here w/ the whole LSx swap. To each their own but some folk just can't accept or respect an owners decision to do what THEY do. It's this or it's that, old, antiquated can do more with less on a LSx build/swap blah blah blah. LOL Just bust their *** on the street or on the track is my way of answering that bullshit. And I own a Z06 too.
See you are in J-Ville. Nice! You'll hit 700rwhp or damn close to it I'd think w/ 15psi.
Very nice setup you're going to have. I'm interested to see what numbers it puts out. I'm glad there's more then a few of us still beating on the LT1s.
We did a D1SC on a H/C LT1 car with 24X and got 630rwhp on the stock bottom end. The customer doesn't drive the car really ever (10k miles on a 97 SS) so realistically it should last a while, however I believe he already has plans to do a bottom end late this year or early next.
Karl Ellwein decided for me on the 396ci, He says with the 6" Rods and custom diamond pistons there will be less "side load" and will effectively live longer.
Hold together....
Well...let's hope not. Callies Dragonslayer crank is a pretty stout piece, so are the Callies Ultra I beam Rods, and the diamond custom pistons should all hold up well. I would say at this point the block is the weak link. Also Karl Ellwein is a master engine builder, and my tuner has many years experience tuning. Should be good to go.
Karl gave me the heads up from the beginning their customer service is sub par, and they take for frickin ever and don't communicate. Ultimately they produce a flawless product...so as long as you can wait and don't mind not having any say in your heads/cam/valvetrain combo and just leave it in their hands then you're good.
Latest and Greatest
Latest and Greatest on the build! I took a drive up to Maryland with the Tahoe to watch the engine on the (engine)dyno then take delivery.
The engine made a solid 526hp and 511ft/lbs with a carb'd intake, 750 carb, distributor with no tuning, just a preset 35degrees of timing. Not the ideal setup for this "blower motor" as it needs the forced air up top to make power. None the less its making some decent N/A hp for the setup.
#32
Thats damn good NA power, especially for the intake that is pictured... With a real intake and carb, you would have made over 550-575hp easy...But I understand this was just a break in/test run.
That being said, assuming your LT4 intake/TB isnt too restrictive, I don't see why you wouldnt make 750 rwhp + out of a maxed out D1sc... (probably more like 800 rwhp depending on your drivetrain loss).. The air hat/filter thing will be the killer for you on the street.
Really cool build, I'm sub'd for final results.
Us old school guys still love SBCs..... We have NA SBCs running around here that kill boosted LS motors...
#33
I feel like it had more in it as well. The Carb was the dyno shops **** of carbs, it goes on all the engines. The friggin thing wouldnt even idle down past 1300RPMs. And the intake pictured is just the standard GMPP LT1 carb intake.
Tuning capability from the LS PCM is key. And I have a fantastic tuner down here in FL.
My intake is a ported LT1 unit from Advanced Induction and the TB is the Arizona Speeed and Marine Monoblade.
I plan on running 15-16psi out of the D1, and down the road upgrading to an F series blower and front mount intercooler.
Drivetrain is a Mcleod twin disc clutch, D&D Viper Spec'd T56, PST 3.5" Driveshaft, Moser 9".
I love the SBC as well, I have a 98 2-Door Tahoe straight axle swapped on 38s with the 5.7 Vortec and I have put a RAM JET intake on that, LS PCM, coil per plug, headers, etc. I have a 4bolt main 355, cam'd 11.3:1 CR waiting to go in it (once I finish the Camaro project).
#34
Hitting a hurdle
Welllll, down to the nitty gritty stuff. so my hub does not fit in the area it is supposed to on the reluctor wheel when pressed all the way in. If you reference the picture here, It is supposed to reside on the green area (where normal LT1 hub would rest). Instead the way my BBC hub fits, it rests on the outside (red circle). I am having a machinist but a chamfer on the hub to make it sit perfectly in the reluctor wheel. I also have to get the procharger spacer machined, after this gets all done so I can take measurements(again). A little set back, but it will be perfect in the end...I have been working on my front suspension assembling the BMR kmember, tubular upper/lower control arms, BMR C5 brake conversion, new struts/springs, etc, etc...will post pictures of that later on.
24x Double Roller reluctor wheel
#35
Front suspension
Mocking up front suspension....basically new everything except for steering rack/pump, spindles and upper a arm mounts (which were blasted&painted). Going with C5 Z06 front brakes.
Mocked up
Mocked up
#37
Got everything back from the machine shop and have perfect belt alignment for accessories, and most importantly the blower.
Waiting for ARP hardware...
#38
LS1Tech Sponsor
Looking really good! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#40
It is a BBC diameter hub designed to work with a sbc crank snout. Had to get a custom timing cover made to make it all work....and the have the hub machined to work with the reluctant wheel....finally got it all sorted out I believe though.
